holley 2300 2bbl leaking
Mar 6, 2008 | 05:53 PM
It's on a 65 with 330HD. The truck starts and runs good. But when I turn it off, the Carb starts leaking from the choke area. any idea?
Mar 6, 2008 | 06:47 PM
Non vented gas cap ? Pop your cap see if the tank is pressurized. I would start there. Manual fuel pump or electric ?
Mar 6, 2008 | 08:21 PM
It has a non electric, one of the common ford truck fuel pumps. The gas cap looks to be okay. It's actuallt very loose.
Mar 6, 2008 | 08:35 PM
This is just a thought but could the float be sticking a little bit and when you shut the engine off the fuel is being syphoned through the vent holes near the choke? I know after my engine has been running and you pull the hose off the fuel pump fuel continues to run out until you clamp the line off. It is just a thought.
Jeff
Mar 6, 2008 | 09:18 PM
This version of Holley has a screw on the side of the bowl. I took it off and it seemed to be at the right level. Thanks
Mar 6, 2008 | 09:33 PM
Quote:
are you pulling the screw with it running or after you shut it down
Mar 6, 2008 | 09:59 PM
After it's shut down while it's dripping from the side.
Mar 6, 2008 | 10:05 PM
your float level may be set high,did you try to set it running
Mar 7, 2008 | 06:31 AM
if float isnt to high you need a neddle and seat.holleys where born to flood.never liked them.
72Truckin
24
Apr 15, 2013 04:41 PM
Brandon Gibbens
May 20, 2012 08:32 AM
johntmcdonald
Jun 1, 2010 09:03 PM
390fe
Jul 15, 2008 11:09 AM
cat house mouse
Mar 11, 2002 06:33 PM
