Body bushings
Old Mar 6, 2008 | 05:44 PM
F0rdF0rever's Avatar
F0rdF0rever
Body bushings
My truck is in serious need of new cab bushings. Ive been reading around the web about poly compared to rubber and I still cant make up my mind which ones id like to use. Some people say that the polys give you a harsher ride. Does anyone have experience with the polys on these trucks?
Old Mar 6, 2008 | 06:03 PM
Butch(OH)'s Avatar
Butch(OH)
Son just installed a set of the aftermarket urethane cab bushings in his 92 350 w 7.3IDI The engine vibes are more prevelant but cant say about ride quality as ride quality is an oxymoron when applied to his 137"WB f350 FWD cab/chassis with flatbed.
Old Mar 6, 2008 | 06:09 PM
F0rdF0rever
Im leaning more towards the poly as they are far cheaper than the rubber mounts. Do you know if he had to replace any of the hardware along with the mounts?
Old Mar 6, 2008 | 06:21 PM
Butch(OH)'s Avatar
Butch(OH)
His 92 is a 55k mile rust free jewel so he didnt need any hardware. The kit came from a local off road store, purdy sure it was $75 OTD
Old Mar 6, 2008 | 06:28 PM
c00nhunterjoe's Avatar
c00nhunterjoe
only reason you should need new hardware is if yours is really rusted, mainly the front core supports take the bulk of abuse, they collect dirt and water right where the bolt is, check it out and order if needed
Old Mar 6, 2008 | 06:49 PM
F0rdF0rever
I heard the best way to get the bolts out was to drill them. Is this true?
Old Mar 6, 2008 | 06:54 PM
c00nhunterjoe
yikes! nope! i put a body lift on my old truck and all of my bolts came right out, i haven't had to drill them nor do i know how you would be drilling them, its a big nut and a big bolt? what do you drill?
Old Mar 6, 2008 | 07:06 PM
Hussler's Avatar
Hussler
Had a friend that put poly on his and it was fine on surface roads but when out on dirt roads he told me the ride was terrible, so he changed back to rubber bushings on the cab.
Old Mar 6, 2008 | 07:14 PM
F0rdF0rever
Well lucky for me there arent too many dirt roads around here. I just ordered the poly set from Summit.
Joe, I read a few posts over on the dieselstop where some people had to drill the bolt out. Mine dont look too bad so hopefully they will come out.
Old Mar 6, 2008 | 07:15 PM
c00nhunterjoe
those must have been pretty nasty to break a drill out, even bed bolts can be removed without drilling even with the nastiest rust
Old Mar 6, 2008 | 07:21 PM
F0rdF0rever
Yeah I dont know. Iv taken some nasty bed bolt out myself. Ill spray them down with penetrating oil a few days in advance.
I cant wait to get this done. My cab sounds like its going to fall off when I hit large bumps.
Old Mar 30, 2008 | 10:47 PM
486Barry's Avatar
486Barry
I just purchased a 97 f350 Crew Cab. My bushing under the rear passenger side of the cab, right above the exhaust pipe, where the cab meets the frame is wasted. Has anyone attempted to replace those? Can I just jack up the rear of the cab and slip in the new bushing? Is this a problem because it is near the exhaust? Thanks.
Old Mar 30, 2008 | 10:57 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
ford forever i tried to ask you in a pm but did you ever recieve the lift blocks???
Old Mar 31, 2008 | 01:20 AM
kawa's Avatar
kawa
If I may can I offer a different point of view. It seems to be the general consencious that rubber bushings are all around smoother and the harder poly and more harsh.
Your truck (s) are 13+- years old and had OEM rubber bushings that are just now wearing out. I would venture to say that the replacement rubber bushings are made of a higher grade of material than the OEM's of yesteryear.
Are you going to be driving that truck in another 13 years? why would you even consider replacing bushings that would give a harsher ride?
JMHO Rog
BWD444
Dec 14, 2016 04:42 PM
lwarrior1016
Jul 19, 2016 06:27 AM
Fordication
Apr 15, 2016 10:59 AM
turbo2256d
Feb 13, 2016 05:01 PM
LCAM-01XA
18
Mar 17, 2010 10:40 PM
