bought a 400M
Old Jan 12, 2002 | 07:13 PM
TrackStar's Avatar
TrackStar
bought a 400M
Ok, so i just bought a 400M with performance cam, 4bbl carb, and intake for $200. it runs strong but a little rough. i was told the spark plug on the drivers side, second one back, was "fouling". something about oil causing the plug not to fire. im not sure. the guy said that if i took off the heads i should be able to figure out whats wrong. this is where i need help. what kind of problem am i looking for? im new to the internal engine thing so if you could break the terms down i would appreciate it. thanks guys, any help is great.
TrackStar
Old Jan 12, 2002 | 07:20 PM
Franklin2's Avatar
Franklin2
bought a 400M
Do a compression test on the engine with a compression guage you can buy at the auto parts store. It should have instructions on how to determine what's going on. If the compression is good, it may be a leaking intake manifold gasket.
Old Jan 12, 2002 | 11:47 PM
shazam's Avatar
shazam
bought a 400M
Holy Cow :
Can You tell me where you found 400M Engine ????
Oh I can See Bill And Bubba should have a field day with this one..
Gotta love it :-X11
Old Jan 13, 2002 | 12:10 AM
GT40man's Avatar
GT40man
bought a 400M
you know we all should just let it go
Old Jan 13, 2002 | 09:51 AM
TrackStar's Avatar
TrackStar
bought a 400M
i debated whether or not to add the M and figured that enough people on this board already say 400M, so i did it too.
Thanks for the tip Franklin, i'll check it out.
TrackStar
Old Jan 13, 2002 | 02:12 PM
GT40man's Avatar
GT40man
bought a 400M
well here we just call it the 400, after all ford did as well
Old Jan 23, 2002 | 03:47 PM
fordguy76's Avatar
fordguy76
bought a 400M
Old Jan 26, 2002 | 11:52 PM
shazam's Avatar
shazam
bought a 400M
OK we had are fun now to fix your problem.
What I use to do if I had one cylinder that was fouling a plug was go one number hotter on that cylinder to help burn the oil that keeps fouling the plug. but if you have to tear into the motor I'd look for bad valve seal or rings. some where the oil is getting in and these are the only ways I know of .
TrackStar
18
Jan 11, 2004 05:05 PM
TrackStar
Mar 15, 2003 07:40 PM
TrackStar
Jan 29, 2003 10:08 AM
TrackStar
Feb 11, 2002 08:45 AM
TrackStar
Jan 27, 2002 02:30 PM
