oil question
Old Mar 6, 2008 | 09:13 PM
  #31
Izzy351's Avatar
Izzy351
You might have to use some fancy adapters. I haven't been into it myself -- I was hoping someone that has would've chimed in by now...
  #32
white Buffalo's Avatar
white Buffalo
You can easily check the point marked "plug" in the diagram above with your finger. You should see some oil in the valley also if the leak is from this point. It is easy to fix without removing anything....
Old Mar 6, 2008 | 09:15 PM
  #33
powerstroke1869's Avatar
powerstroke1869
yea i also have oil on the backside of my oil pan im assuming that its running on the bottom of the motor... i just did both pedistal o-rings today and still leaks... can you see the plug or do you need a mirror... also what does IPR stand for thanks fellas
Old Mar 6, 2008 | 09:39 PM
  #34
Izzy351's Avatar
Izzy351
IPR is the Injector Pressure Regulator. You should be able to see it if you look at just the right angle...
Old Mar 6, 2008 | 09:41 PM
  #35
powerstroke1869
alrite thanks for the help again guys love this site and great bunch of guys and gals on here
Old Mar 6, 2008 | 09:54 PM
  #36
Izzy351's Avatar
Izzy351
You got it, man!! Good luck with the oil leak.
EburgHDFord
EcoBoost (all engine sizes)
17
May 24, 2011 10:19 AM
baracade
Crossovers
Dec 5, 2010 09:50 AM
HzrInAz
13
Sep 13, 2003 06:30 PM
davidwruth
May 13, 2003 02:57 PM
HiWillis
Oil & Lubrication
Mar 14, 2002 06:58 AM
