351C flywheel options
Old Feb 12, 2002 | 11:54 AM
fordy's Avatar
fordy
I have a 351C-2V with FMX transmission. I want to couple this engine to a T-5 or Tremec. What are my flywheel options for this engine? Would these flywheel options change for a Toploader or ZF 5 speed?
Fordy
1978 F-250 Custom
1996 T-Bird
Old Feb 17, 2002 | 06:11 PM
FortyFords's Avatar
FortyFords
[updated:LAST EDITED ON 17-Feb-02 AT 07:13 PM (EST)]I beleive you can use pre 81 flywheel
with 157 teeth /28.2oz. weight
302/351w and some 289 engs had these.
make sure you use the correct harmonic bal.to match the flywheel.
fordmotor sports sells them also summit racing.
Rich
Don't know about zf5 speed spec's
Ford Trucks Built Tough!
not with rocks
Watch out Mr Mayor of Truckville
Old Feb 18, 2002 | 11:00 PM
xyfalcon500's Avatar
xyfalcon500
This is more for trivia than anything else, but here in Australia there were two different flywheels for the 351C; the 302C came with a different flywheel/starter combo than the 351C. I know this because when I made my 302 into a 351 I couldn't use the starter off a factory 351C, unless I also changed the flywheel.
Old Feb 19, 2002 | 07:17 PM
fatdaddy's Avatar
fatdaddy
bmadden177
Apr 15, 2015 01:00 PM
BushyTea
Jan 25, 2015 07:14 PM
Chris Popanz
Nov 4, 2014 10:46 AM
Scndsin
Jun 1, 2014 07:28 AM
rangerottis
May 23, 2014 03:57 PM
