C6 Auto Swap - Flywheel & Separator Plate
Vehicle: 1966 F-100
Engine: 351 Windsor from 1971 Torino
Trans: C6 Auto Trans from Monster Transmission
I have removed the 351 Windsor from my truck as well as the T18 4 speed manual trans. However, while gathering parts for this swap I overlooked the separator plate for the C6 auto transmission. I have the manual plate but from what I read this will not work with the auto transmission.
Where is the best place to find the separator plate for my 351 Windsor / C6 auto trans?
Next, the flywheel I am trying to use is a 28oz externally balanced 164 tooth flexplate. The issue I am having is that the holes on the flywheel never seem to fully line up with the holes on the crank. I bought the flywheel based on what the engine was from which was the 71 Torino. I can get all 6 bolts started but then the flywheel won't push back onto the crank. It is as if the bolts are causing a bind. Below is the flywheel I purchased.
Pioneer/Flywheel - Automatic Transmission FRA-205 at AutoZone.com
Anybody else ever have an issue like this or could the flywheel be wrong or possibly machined wrong?
Thanks in advance
Thanks in advance
Flexplate = Automatic Transmission
Flywheel = Manual Transmission
It does sound like the flexplate might be machined incorrectly. If it's made for a 351W but doesn't exactly fit a 351W - what else could it be?
This product is a fit for your:
1971 Ford Torino 5.8L 2BL 8cyl
<!-- in case of match, only show when checkfit parameter is true -->
Part Number: FRA-205
Good point for consideration. It always takes me six tries to get it right. Lol. Luckily the flexplate should be a lot lighter than the flywheel so he could spin it in circles until the holes line up.
Thanks for the info guys. I have always used the term flywheel as the general term whether manual or automatic. Just a force of habit I guess.
Thank goodness for the flexplate being lighter since the flywheel I took off was a boat anchor. As for the flexplate, I have rotated it many times and it does get to one point where it seems all of the holes line up.
However, one or two holes are just a hair off but it is in the position where they line up the best. Maybe the bolts I am using are causing it to bind. I will keep working on it and see since if I can get it since this is the correct flexplate.
Any ideas on a good place to find the separator plate for the C6 auto? I can't seem to locate one locally.
Thanks again
Thanks again
1971 Torino available with 302 - 351C - 351W - 400 - 429 // 302/351W have 6 valve cover bolts per side, 351C/400 have 8 valve bolts per side.
Fairlane/Torino: Parts catalog symbol = B // A = LTD / F = Mustang / G = Granada / P = Maverick / S = T-Bird / U = Bronco
D2TZ-7007-A (replaced D0AZ-7007-A .. Engine rear plate-same C4/C6 FMX (see car parts catalog apps) / Also same: 1969/79 F100/150 & Econoline 240/300/302 & 1975/79 E100/350 351W
Thanks for the information Bill. You are always a huge help.
I do have a member here who has a separator plate available but it is from a 1980 Mercury Monarch. I believe these cars did have a C4 trans and the plate looks like the plates with the part number you provided.
Does a separator plate from a 1980 Mercury Monarch work as well? I just want to make sure before I buy.
Thanks again,
Mike
Thanks again,
Mike
No other 1980 or later car uses the correct plate.
Here are the 1973/79 Ford Passenger Car Parts Catalog applications for D2TZ-7007-A
A = LTD / B = Torino/Ranchero/LTD II (not an LTD!) / F = Mustang / G = Granada / P = 1977 Maverick - 1978 Fairmont / S = Thunderbird / U = Bronco.
Well, possibly a change in parts needed due to new information.
Engine: 302 instead of 351W
Trans: C6 Auto
I was told the motor was a 351W when it was rebuilt many years ago when my parents owned the truck. However, after further investigation and some issues with flexplate fitment I have now found out that the motor is a 302. I am not 100% sure on going with the 302 now but in case what differences am I looking at for the flywheel & spacer plate?
I believe from my research this means a totally different flexplate. Possibly a smaller O.D. 157 tooth flexplate? Also does the same spacer plate D2TZ-7007-A work for this application?
Thanks
Trans: C6 Auto
Thanks
302 not available with C6 in F100/150 until 1978, not available in Passenger Cars until 1979.
D1ZZ-6375-A .. C6 Flexplate-164T / Obsolete
1971/73 Fairlane/Torino/Mustang/Cougar 351C 2V/4V (except 351C 4V Cobra Jet) & 351W 2V / 1974 Torino/Cougar 351C 2V & 351W 2V
1975/80 Econoline 351W / 1978/80 F100/150 302 / 1979/80 302 Passenger Cars / 1981 Econoline 351W except CA / 1982/91 F150/350, Bronco & Econoline 351W
Is the spacer plate the same part # D2TZ-7007-A?
Thanks again,
Mike
I have been searching and looking through the part numbers that Bill provided above and it looks like the part # could be D90Z-7007-A. However, the part number D2T2-7007-A shows that it will work with a 240, 300, 302, 351W with A/T.
I just want to confirm before painting in case I need to return the plate that I currently have.
Thanks in advance.
Thanks in advance.
TexasTornado66
10-21-2011 11:40 PM
Boss50
05-19-2006 08:32 AM
