1970 Ford 302 Flywheel
Old May 22, 2014 | 11:56 AM
rangerottis's Avatar
rangerottis
Converting from a C4 to a 3.03 manual in my 1970 f100 302. Apparently there are 15 million flywheel options! I want to know if any 28 oz imbalance flywheel will work without destroying my engine? And if the 10.5" clutch uses the same pressure plate bolt pattern as an 11"? Any help will be much appreciated!
Old May 23, 2014 | 03:57 PM
baddad457's Avatar
baddad457
You need a 28 oz/in flywheel that matches your bellhousing. The 10.5 pressure plate has a different bolt pattern vs an 11" pressure plate. If the bellhousing you're going to use is cast iron, chances are it's a 164 tooth bell and uses a 164 tooth flywheel to allow the starter to line up to the flywheel's teeth. You also need the block plate that's sandwiched between the block and bell, this part indexes the starter to the flywheel to insure the correct tooth engagement.
mh822
102
Dec 5, 2025 03:49 PM
junkyarddog82
Feb 12, 2008 09:53 PM
mh822
Feb 19, 2006 04:56 PM
jeepnford
Engine Swaps
Jun 18, 2004 01:25 PM
ent
Oct 23, 2000 04:15 AM
