Simple Theft Deterrent Method
Old Mar 7, 2008 | 09:18 AM
  #61
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by miller_feed
Not only a date, but guess where the putton for the bomb is.
I can just see the news story now..
GRAND LAKE, LOUISIANA - Authorities said Friday that a local madman, tiring of the consistent theft of his Powerstroke Diesel, decided to strap 2 pounds of C-4 to what has been described as a blow up doll to exact revenge on the would-be thieves.
"It was awful," said local Sheriff Mr. McGee. "All we found was a plastic blow up doll mouth and a bunch of blood and guts."
Old Mar 7, 2008 | 09:36 AM
  #62
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I guess I forgot about the placement of the button.
Old Mar 7, 2008 | 09:41 AM
  #63
superduty4x4's Avatar
superduty4x4
Originally Posted by F350-6
I think your looking at the diagram for the under dash fuses. Attached is the diagram for the under hood fuse block.
That's the diagram I was looking at, but when I go out and look at the lid on my underhood fuse panel the numbers are different- Relay 1, Relay 2, 3, 4, 5... Relay 32 in the manual is Relay 4 in the underhood fuse block.
Old May 23, 2008 | 05:39 PM
  #64
rangergurl04's Avatar
rangergurl04
ok question, think this could be worked into a ranger in anyway? if so, which relay would i use?
Old May 23, 2008 | 07:58 PM
  #65
F350-6's Avatar
F350-6
Do you have your owners manual handy Sara? You won't have an IDM relay, but maybe you have one for the starting circuit, fuel pump, or PCM. The simple way to test this would be to look for an important sounding relay in the manual. When you find a candidate, pull the relay out and try to start the truck. If it doesn't start with the relay removed you've found the right one.
Old May 23, 2008 | 08:35 PM
  #66
rangergurl04
ok thanks! i'm gonna be doin some work on the truck this weekend so i'll pull the book out and try it
Old May 25, 2008 | 10:58 AM
  #67
usmc5953's Avatar
usmc5953
You could also make a few swithces combine as a combo, one up, one down, one up. If you turn them the correct way when you install them, then you could put them in a place where they could be seen and not worry. Just a though, although as I write I think of where to put more than one switch. Anyway just a idea.
Old Jan 15, 2020 | 07:20 PM
  #68
Jregezeino's Avatar
Jregezeino
While I was thinking about how I wanted to install my theft deterrent, I came up with something clever. In addition to adding a switch to the injector relay, why not make it a DPDT switch that when in “deterrent mode” not only do the injectors not fire, but the horn blows while cranking the motor!! Wire the ignition switch 12v to the horn relay via the second pole on the switch, now that would get the thief running for the hills at 3am!
Good luck stealing that truck!
Old Feb 22, 2022 | 01:38 AM
  #69
Tortillas's Avatar
Tortillas
Pictures
Originally Posted by RAMPAGE_F350
First off, I want to give credit to Scott (Texas Outlaw) and Marv (SpringerPop) which is where I got this idea from in the first place. The first Theft Deterrent Thread hit home for several people, but they didn't know where to start and didn't want it complicated. No offense Marv, your design is brilliant!
The idea of having to pull off the fuse dash panel and then the fuse box cover to remove Relay 303 (Injector Drive Module Relay) is a little inconvienent to say the least. Especially, if your like me and want to disable your truck everytime you shut it off. Here is an idea that I just tested, its simple, its cheap, its reversable, and it works.
This Mod reqires removing Relay 303 and relocating it just outside of the fuse box and installing a toggle switch for interupting the relays ground connection to the fuse box.
You will need:
-5 male crimp-on blade connectors
-7 insulated female crimp-on blade connectors
-1 toggle switch (choose your style)
-At least 8 feet of 18 guage wire, or more depending on where you plan on mounting your toggle switch.
-1 small zip tie
-Cut 4 pieces of wire 12 inches long, crimp a male blade connector and a female blade connector on each end of the 4 wires.
-Locate the numbers on the relay near the blades, connect the 4 wires to the 30,87,87a,85 terminals.
-Attach the other ends of the 4 wires to the corresponding blade recepticals in the fuse box, where relay 303 was originally.
-Locate your secret toggle switch location, cut a wire long enough to reach from the toggle switch to the relay, crimp a female blade connector on each end of the wire.
-Attach one end of the wire to the toggle switch and the other end to terminal 86 on the relay.
-Cut another piece of wire long enough to go from the fuse box to the toggle switch, crimp a male blade connector on one end of the wire and a female connector on the other end.
-Attach one end to the toggle switch and the other end to the remaining open blade receptical that blade 86 would plug into on the fuse panel.
-Carefully route the five wires toward the right of the fuse box and reinstall the fuse box cover, the fuse box cover may need to be notched to ensure the wires are not pinched when latched.
-Zip tie the relay to a desired location.
-Test
The first pic is a small version that I made to test with, you should get the idea though. The second pic is of a 2002 fuse panel indicating the location of Relay 303. I made this detailed so anyone could attempt this Mod no matter what their electrical skills may be. Hopefully this helps you guys! Good Luck!
can we get those photos added again? Thanks
Old Feb 22, 2022 | 02:25 AM
  #70
josht's Avatar
josht
Unlikely, the dude hasn't been active since 2016. Sounds simple enough to not need pictures. Are you a spammer/spam bot trying to sneak in? This looks like a post they'd make.
Old Feb 22, 2022 | 09:08 AM
  #71
F250_'s Avatar
F250_
You're right, Josh, Chris (Rampage) has not been here in a long time. However, Marv (SpringerPop) checks in periodically and may get wind of this with a reply, since he was one of the original contributors to the concepts outlined by Rampage to begin with.
Old Jan 18, 2023 | 08:55 PM
  #72
EconoRyan's Avatar
EconoRyan
I'm going to add a switch to the starter solenoid wire b/c it sounds easier and is what i am looking for. I'd ask how, but i'll check it out.... Ie which wire? lol.
Old Jan 19, 2023 | 09:11 AM
  #73
knottyrope's Avatar
knottyrope
Starter can be bypassed with a piece of metal
breaking the CPS ground or IPR power would be easy to wire in a switch inline
Frank79
Dec 21, 2019 08:49 PM
191124x7
Feb 22, 2019 11:49 AM
BCM
Jul 28, 2017 06:47 AM
NWcountry
Electrical Systems/Wiring
Jun 27, 2005 11:29 AM
f-4x4
Dec 18, 2004 02:18 PM
