Simple Theft Deterrent Method
Old Mar 5, 2008 | 10:48 PM
  #46
superduty4x4's Avatar
superduty4x4
Originally Posted by F350-6
I looked through an online copy of the 99 owners manual and did not see an IDM relay. It looks like you can do the same thing with your #30 PCM power relay located under your hood if you wanted to stick with a realy. You could do the same thing with your famous #30 fuel bowl heater (&PCM) fuse located under the dash.
Do you have a link to the online manual? My truck doesn't have one unfortunately I don't remember seeing a #30 relay, I'll have to look again.
Old Mar 6, 2008 | 12:27 AM
  #47
twags6's Avatar
twags6
Enter your year, make, and model and you can download the entire manual in pdf form. https://www.fleet.ford.com/maintenan...ls/default.asp
Old Mar 6, 2008 | 08:19 AM
  #48
superduty4x4
Awesome, thanks Trevor!
Old Mar 6, 2008 | 08:35 AM
  #49
superduty4x4
So after looking at the manual online, it looks like on the 99 the IDM is controlled only by a fuse, not a relay so this may not work on 99 model trucks
Old Mar 6, 2008 | 08:50 AM
  #50
F350-6's Avatar
F350-6
No, you have one. Look again in the owners manual. It's relay # 32 for the IDM. Post #44 has a link to a photo of the one in Springerpop's truck.
I missed it the first time too.
Old Mar 6, 2008 | 08:58 AM
  #51
superduty4x4
Heh... okay, so I get the "DOTD" award for today (dumb***** of the day)
Old Mar 6, 2008 | 10:27 AM
  #52
badger2196's Avatar
badger2196
Originally Posted by RAMPAGE_F350
The overhead console (if you have one), what thief is going to look up. You could put it on the inside of the garage door opener compartment or the sunglass holder compartment.
I don't know if its legal for you guys that have vehicle inspections, but turn the hazard light button into your activation switch. Its out in the open, easy to get to and is naturally unsuspecable as an anti-theft switch. I don't know about you but I have never used my hazard switch. Just a couple of ideas.
For switch location, my buddy put two switches in the circuit that both had to be operated for the truck to start. This makes it harder for the thief as he has to find two hidden switches rather than just one and will hopefully give up after he finds the first switch but still can't start the truck. Just another idea to throw into the mix.
FYI, his setup interrupts the power to the clutch pedal sensor (on the 6 spd, the clutch pedal has to be pressed for the truck to start)
Old Mar 6, 2008 | 11:22 AM
  #53
rad1026's Avatar
rad1026
I use this:
http://www.alphalock.com/
In addition to an alarm system and a steering wheel lock. I'm not so much worried about someone jumping in my truck and getting it started as I am backing up a tow truck and taking off. I know most hackers don't use tow trucks but the tire lock goes on in like 5 seconds and its a big visable deterrent.
Old Mar 6, 2008 | 11:44 PM
  #54
superduty4x4
Okay, I looked at my underhood fuse panel again tonight. My panel looks like the one on SpringerPop's truck, but there is NO #32 relay, it was a single digit number (4 maybe). I suppose I could just pull the relay and see what happens. The numbering the manual vs. the lid of the fuse box is different, it's worth a shot.
Old Mar 6, 2008 | 11:45 PM
  #55
greythorn3's Avatar
greythorn3
get a blow up doll and put it in the drivers seat, then they will think somones always in it.
Ray
Old Mar 7, 2008 | 08:15 AM
  #56
F350-6's Avatar
F350-6
I think your looking at the diagram for the under dash fuses. Attached is the diagram for the under hood fuse block.
File Type: pdf
Old Mar 7, 2008 | 08:45 AM
  #57
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Ray
Annnnd, if you're ever lonely and have the urge then you're all set.
Old Mar 7, 2008 | 08:51 AM
  #58
Smokin''s Avatar
Smokin'
Smokin
Ray
What makes you guys so sure the addition of the blowup doll won't persuade someone to steal the truck even more?
The thief gets a ride and an easy date.
Old Mar 7, 2008 | 08:55 AM
  #59
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Not only a date, but guess where the putton for the bomb is.
Old Mar 7, 2008 | 09:14 AM
  #60
DR JOE's Avatar
DR JOE
In my new motorcycle mag that I got a few days ago, they have a new system that is for bikes that replace your starter relay. If the key fobbie is not with in range, the bike will not start. Could work on our trucks the same way. I will find out more about it and post the info here. That could be a very easy way to protect our trucks... For not a whole lot of money...
Doc.
