Overflow Question
Old Mar 3, 2008 | 11:44 PM
coop923's Avatar
coop923
Overflow Question
Just curious...
My 64 F100's original radiator that I replaced about 15 months ago had some sort of JB Welded hard line contraption that ended into a drip hose connected to the overflow valve nipple at the cap. When I finally replaced the radiator, I left it off thinking I'd address it later. Did the 64 F100 (292) come with an overflow bag or tank and, if so, is it something I should have on there now? It does spew a little coolant sometimes when I shut it off.
If so, bag or tank, and can anyone tell me where I might start looking?
Thanks,
-Mark
Old Mar 4, 2008 | 02:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by coop923
Just curious...
Thanks,
-Mark
Ford didn't offer a factory installed coolant recovery tank on F100/350's till 1971, but they did offer an accessory kit (D0AZ-8522-A) available at the parts counter to install one on earlier models. Similar kits are available from parts stores.
Old Mar 4, 2008 | 05:54 AM
jowilker's Avatar
jowilker
Mark, Most of us have learned that the radiator needs a little expansion room in the top. Check it at startup until you are comfortable, but run it and let it puke out what it needs to. As long as you can see fluid or touch it with the end of your finger, you are ok. I will leave it a couple inches down to allow for expansion on any truck that I am working on.
John
Old Mar 4, 2008 | 10:15 PM
coop923's Avatar
coop923
Thanks for the info. I'll let it drop and keep an eye on it.
-Mark
Old Mar 5, 2008 | 06:37 AM
jowilker's Avatar
jowilker
How about posting back here in about a week and let us know how it turned out.
John
Old Mar 5, 2008 | 10:17 PM
coop923's Avatar
coop923
Will do. I'll let it drop a couple inches and see what happens.
-Mark
96_F250_Deezal
Jan 23, 2014 09:19 PM
DutchB100
Jan 8, 2012 04:58 PM
flipklos
Mar 15, 2010 08:10 PM
Montana2mass
Oct 21, 2008 10:40 AM
dativer
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 30, 2004 01:35 AM
