coolant overflow tank
Old Jan 22, 2014 | 08:11 PM
96_F250_Deezal's Avatar
96_F250_Deezal
Question coolant overflow tank
recently, after my long commute to and from work with the heat going, when I turn the truck off, coolant overflows from the radiator cap.
2 weeks ago I replaced the overflow tank and radiator cap. About a year ago I flushed the cooling system, ran restore through the system and refilled with distilled water and no silicate green coolant.
I am really confused, since the truck doesn't overheat and the coolant and oil temps show normal on the scan tool.
Old Jan 22, 2014 | 08:20 PM
egregg57's Avatar
egregg57
Stupid question .... this is a 6.0L your talking about, correct? If so what silicant free "green" coolant did you use?
Need year, miles, mods if any, to better help.
Old Jan 22, 2014 | 08:30 PM
96_F250_Deezal
seriously?
It's the truck in my signature, 212,500 miles. It's stock, except for a SRL tune.
Napa coolant.
Old Jan 22, 2014 | 08:36 PM
egregg57's Avatar
egregg57
Sorry can't see signatures on my mobile phone.
Old Jan 22, 2014 | 08:42 PM
bismic's Avatar
bismic
Uhmm probably another reason he asked is because of your forum name .................
The green coolant is really not recommended for the 6.0L - lots of folks reporting cavitation of the front cover from using it.
Also - they are really not overflow tanks the way this system is designed - flow passes through them to allow gasses to separate from the liquid - they are called degas bottles.
Tell us how full do you fill the degas bottle? The best move next would be to put a pressure gauge on it.
Old Jan 22, 2014 | 08:48 PM
davidstereo's Avatar
davidstereo
If you look in the tech folder there is a full write up on coolant loss diagnosis procedure. What are your eot/ect deltas?
Old Jan 22, 2014 | 08:55 PM
96_F250_Deezal
never heard that about green coolant. maybe I need to flush again and refill with Cat ELC.
degas bottle is filled the MAX line.
Old Jan 22, 2014 | 09:01 PM
egregg57's Avatar
egregg57
You want to use Motorcraft Gold coolant or after a complete system flush, ELC coolant. "Green" coolant is not for this engine and is going to cause problems like what you are describing and some other nasty stuff. Gotta get that stuff out of there.
96_F250_Deezal
don't remember the numbers, but I can put the scan tool on it again and look.
Old Jan 22, 2014 | 09:02 PM
bismic's Avatar
bismic
You should only fill it to the minimum line. Ford issued a TSB about that. The heat was causing enough expansion of the coolant to "pop" the relief valve (cap) when it was at the max line. In the early days, this made people start thinking of head gasket or EGR cooler failure, when it really wasn't.
As far as the green coolant goes, it is somewhat debated, but most mechanics I know shy away from it in the 6.0L because of the reason mentioned above (I know a few Techs on here have seen the cavitation).
So, there is no release of fluid until you shut down? Definitely unusual! Do you still have the EGR system? Definitely let us know the ECT's and EOT's. I have a pressure gauge on the tank - it is a very handy tool in troubleshooting coolant loss.
Old Jan 23, 2014 | 09:19 PM
96_F250_Deezal
ok, looks like the coolant level is over full. I will get the level down and keep monitoring the situation. when It warms up, I will get all the green coolant out and switch to the Cat ELC.
BrianV_
Oct 18, 2018 05:16 AM
aa777888
Apr 10, 2005 01:45 PM
pcerra
Feb 21, 2004 08:14 PM
F0rdF0rever
Sep 15, 2003 10:28 PM
AlM
1978 - 1996 Big Bronco
Oct 11, 2001 01:34 PM
