What is this?
Old Mar 5, 2008 | 01:31 PM
whayes75's Avatar
whayes75
What is this?
I got my truck last year. I don't know much about the history of the truck.
I had the door panel off and saw these black squares of rubber on the insides of the door. what are they?
does this mean it has been repaired? Or were they put in there from the factory?
<img src="http://homepage.mac.com/greylc/truck1.jpg">
<img src="http://homepage.mac.com/greylc/truck2.jpg">
Old Mar 5, 2008 | 01:34 PM
85e150's Avatar
85e150
Factory effort to reduce the sensation of being inside the bass drum at a Led Zep concert....
Old Mar 5, 2008 | 01:38 PM
airharley's Avatar
airharley
I think 85e150six4mtod is on track with his thought. There are a couple of ways to reduce niose. I do know they used a spray on tar like substance. I haven't seen the patches like that though.
Old Mar 5, 2008 | 01:55 PM
camperspecial65's Avatar
camperspecial65
looks factory to me...esp. as clean as the door is inside...I tried emailing you but it says you cant get emails yet...drop me a note...I love the truck very much.
- cs65
Old Mar 5, 2008 | 02:18 PM
whayes75's Avatar
whayes75
I should be able to receive email now, for some reason I had it turned off.
Old Mar 5, 2008 | 02:22 PM
camperspecial65
you got mail....
Old Mar 5, 2008 | 05:09 PM
tbritt's Avatar
tbritt
THROW A MAGNET ON THE OUTSIDE AND THAT WILL CLEARUP THE REPAIR THOUGHT,I'M WITH CAMPER65, WAY TOO CLEAN TO HAVE BEEN REPAIRED..tbritt
Old Mar 5, 2008 | 06:16 PM
Shoveldog's Avatar
Shoveldog
Pull up your rubber floor mat if that's still in yours. I'll bet you see the same stuff under that. Sound deadener.
Mike
Old Mar 5, 2008 | 06:20 PM
FitchBanjos's Avatar
FitchBanjos
Mine has it too. It is factory installed sound deadener.
Old Mar 5, 2008 | 08:02 PM
whayes75's Avatar
whayes75
thanks for all the responses.
Old Mar 6, 2008 | 06:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Factory sound deadener
It's a product called Butyl Rubber. It was (is?) available from automotive paint supply stores.
It came in a 3' sheet, so it was cut to fit.
It was glued on by an trim cement (C2AZ-19C525-A). The same stuff was also used to glue the padded dashes on, etc.
tschoepe
Texas Chapter
35
Jan 23, 2011 09:01 PM
tschoepe
May 17, 2010 04:37 PM
tschoepe
Texas Chapter
Apr 30, 2010 03:00 AM
pronstar
Jan 22, 2007 11:59 AM
Joel_CA
Nov 24, 2004 08:47 AM
