Speedometer Cable
Old Mar 3, 2008 | 07:06 PM
Voh's Avatar
Voh
Speedometer Cable
CAn someone please point me to a good source for a speedo cable. I installled a C6, so i need it to be longer then what i guess is the stock one i removed with the C4. Stock speedo & C6 transmission.
I also need a speedo glass for the stock cluster. Thanks.
Old Mar 4, 2008 | 04:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the truck? Your profile says 1964. If that's correct, the original cable was 63 inches long. How much longer do you need?
1968/72 F100/250's with a C6 have a 75 1/2" cable: C7TZ-17260-AB.
C7TZ-17260-U ~ FTE sponsor GREEN SALES has one of these. It was used on 1971/72 F100/350's with a 4 speed, but the hookup is the same. It's 75 1/4" long.
Before going any further...I need to know the approximate length, there are literally dozens of cables to choose from.
Old Mar 4, 2008 | 08:37 AM
Voh's Avatar
Voh
I would say that i need somewhere around the 75" or so. It almost reaches to connect at both ends. I took the cable from the '73 doner truck, but the head end of it is very different on the newer generation. I was thinking that I might need to have one made.
Old Mar 5, 2008 | 03:55 AM
NumberDummy
1973 and later: The cable connects to the speedo head with a clip.
The pre 1973 cables screw on to the speedo head.
Look for one from 1967/72. C6's used the same cable 68/72 that '67's with COM did.
Don't limit your search to trucks, a car speedo cable will also work. Same ends, same trans and speedo head connections.
Example: C3DZ-17260-F .. Cable & Housing ~ 74 9/16" long.
Fits: 1963/65 Falcon with a 4 speed / 1964/66 T-Bird with COM / 1966 T-Bird with a C6.
ravens fan
Dec 18, 2015 09:21 PM
pitdog0938
Apr 20, 2015 12:54 PM
jayro88
Aug 18, 2014 11:56 AM
march
Mar 9, 2014 08:10 PM
grey77
Mar 21, 2005 08:24 AM
