C-6 advice please...
Old Apr 20, 2015 | 12:41 PM
pitdog0938's Avatar
pitdog0938
Ok so my truck has a lag when I put it in gear, fluid is clean and full. If I increase the rpm's to about 2000 it goes into gear hard. Does the modulator affect this or just 1-2-3 shifts? The truck is new to me and not on the road yet so I don't know what it does in that respect. Also where can I get a speedo cable to go from this trans to my stock speedo? 65 custom cab sweep speedo if it matters.
Old Apr 20, 2015 | 12:51 PM
yellodog's Avatar
yellodog
hard seals, lets the fluid bypass till you raise the rpm's enough to overcome the lack of volume. try some trans conditioner, it should soften the seals and correct the problem you're having. but at some point in the future you're in for a trans overhaul, no biggie with a c-6
Old Apr 20, 2015 | 12:54 PM
pitdog0938's Avatar
pitdog0938
I have an extra trans any idea approximately how much to have it rebuilt?
svemike
53
Oct 19, 2016 12:42 PM
oldiron
Feb 13, 2010 10:41 PM
cpettymore7777
Sep 11, 2009 05:21 PM
GeneStoner
Oct 23, 2006 09:57 PM
ohrtman19
1978 - 1996 Big Bronco
Mar 20, 2004 11:34 PM
