i have a 85 with a 6.9 diesel in it and i want to get me some rockwell 2 and a half ton axels and was wonderin what i would have to do to get them to fit under my truck
not sure they would completely fit UNDER the truck as they are a good bit wider than the 250 axles. i think i'm right about that. checked on doing that to a '70 bronco i used to own and was going to have inspection problems since the wheels hung way outside the sheet metal. if i remember things halfway clearly, all the driveshafts would have to be different and the axles would have to be angled (rotated from normal position) so the differentials would not have an excessive amount of driveline angle. it's almost the same problem as jacking one up and not rotating axles.....puts so much stress on u-joints that they tend to grenade under pressure/load. not saying it can't be done 'cause it has, but not sure it's worth the aggravation and expense.
Let me look here in the next day or so, there is a 2000 F350 Stroke in a garage a block from my house with Rockwells under it.
We are supposed to have rain tomorrow, so if the owner is over there working on it I will take a picture or two.
What you are wanting to run for tires will have a lot to do with how well it will fit.
That one next door has 53's on it.
Oh there is one more thing, the only gear ratio is 6.72, so speed will not be an option.
With a ZF 6 and 53" tires Robbies truck will be running 105 MPH at 3300.
With 35's and a four speed, 51 MPH would be 3300 RPM.
