Piston?
Old Mar 2, 2008 | 10:33 PM
MER's Avatar
MER
Piston?
Of all the flat top pistons you guys are using the 390,360 352 351W which one is the easiest to put on 300 Rods? THANKS! IN ADVANCE
Old Mar 3, 2008 | 08:43 AM
Silver Streak's Avatar
Silver Streak
That depends on the block. If it will take a +0.050 overbore the 390 pistons drop right in. If you can't do that you're stuck with something else. The easiest would be to find a set of flattops for a 300. They are out there somewhere, but I don't remember who makes them. Custom pistons are also a possibility and might prove to be cheaper and easier than anything else in the long run.
Old Mar 5, 2008 | 06:11 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
I shoulda did the 390 piston swap when I did mine, but I talked to Silver here about a month to late. Anyways I was looking into it agian, I know once b4 I had stumbled upon flat-tops for a 300 but they weren't cheap, at all! The 390's were a much better deal, my only problem was I already went .060" over, I am debating if I should try .070" over and use 390 .020" over pistons, I could not find a .010" over for em, guess I didn't really expect to. Anyways do some searching on the internet, I have found them b4, maybe start w/ clifford, otherwise now it's bugging me, I'll look for em to, if I find em I'll let you know.
Old Mar 5, 2008 | 06:50 PM
Harte3's Avatar
Harte3
http://cgi.ebay.com/ebaymotors/Ford-...em150222397998
Set of Forged Pistons on FleaBay at this time.
Old Mar 5, 2008 | 06:51 PM
MER's Avatar
MER
Hey Cowboy, Thanks, if you find them let me know.
Old Mar 6, 2008 | 10:37 PM
Redneck-Cowboy
Ok, the only pre made piston I could find is at www.venolia.com (no price though), other then that bill miller will make you anything you want, just search the name and "piston", but after reading a extenive amount of posts in the fordsix forums it looks like most ppl when talking about flat-tops are just referring to an FE block piston. Well I tried, I thought at one time I found some somewhere with prices but they've disapeared or else I'm thinking of the giant price jump from .060" over to .080" over, which are also out there.
teederj2002
Jan 21, 2005 05:56 PM
danlee
33
Sep 25, 2003 06:59 PM
trinogt
24
Aug 20, 2002 07:08 PM
bigeric
Mar 14, 2002 08:56 PM
BB
Sep 4, 2001 06:23 PM
