Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Wiring
Old Feb 29, 2008 | 09:42 PM
  #46
96sherm's Avatar
96sherm
single wire would sure look neater, but a good wire cover could make it look tidy too...
Old Feb 29, 2008 | 09:45 PM
  #47
51dueller's Avatar
51dueller
I don't see a link. What I wrote is actual fact and I listed other sources of this info. I hope I don't need to drag my old mechanic text book out of the closet and go indepth with transistors, voltage biased diodes, zener diodes, diode trios and rectifier bridges to backup what it better explained by the above links.
Old Feb 29, 2008 | 09:47 PM
  #48
Snowking's Avatar
Snowking
What I always though might look cool and might still do to my 1967/69 trucks is to run light guage conduit and junction boxes, still playing around with it.
But for my 1949 I'm just trying to elimate all unessary wires even switching to mechanical guagesand elimating the old electric ones in the future.
Old Feb 29, 2008 | 09:50 PM
  #49
Snowking's Avatar
Snowking
Don't you get it nobody cares. Performance IS NOT the ****ing reason I'm switching to 1 wire.
Old Feb 29, 2008 | 10:06 PM
  #50
effie_man's Avatar
effie_man
*chris cheers, finally someone said it
Old Feb 29, 2008 | 10:11 PM
  #51
51dueller's Avatar
51dueller
How said anything about performance? I just hope you have fun when the GM alternator starts causing electrical problems.
Old Feb 29, 2008 | 10:14 PM
  #52
effie_man's Avatar
effie_man
you know i sure miss it when you stayed on the 48-60 forum, Ive had enough of this bull**** dont expect to be seeing meon this ****ing site anymore. Ive had it with your know-it-allism. If we wanted to know we would ****ing ask, otherwise keep it to yourself.
Old Feb 29, 2008 | 10:39 PM
  #53
Snowking's Avatar
Snowking
That is putting it blunt but ya sometimes you gotta cool it Nathan if we wanted actual technical advice and more expierence with actual setups.
Old Feb 29, 2008 | 10:47 PM
  #54
51dueller's Avatar
51dueller
Hmm... Cool it? I just pointed out the difference between the two types and provide a link to some good quality information about GM alternators. You mock me, then swear at me and I'm the bad guy?
Old Feb 29, 2008 | 11:14 PM
  #55
preppypyro's Avatar
preppypyro
Ryan I like the idea of running conduit to tidy the wiring up. On the right vehicle that would be a good look.
What would you personally use for conduit though? Im an electrician, so for me I picture plastic pipe haha.
Old Feb 29, 2008 | 11:19 PM
  #56
Snowking's Avatar
Snowking
thin guage galvanized I was thinking of, the type used primary indoors in industrial/commercial buildings. I think it would go good on Ford trucks primarily with smaller metal inner fenders (not so much on modern trucks)maybe on newwer Ford truck with more of a plastic/fibre fender a PVC plastic conduit would blend in nicer.
Old Feb 29, 2008 | 11:26 PM
  #57
preppypyro's Avatar
preppypyro
I know the conduit your thinking of. It might be ok. I dont remember how small a guy can get it.
If a guy could paint it the same as the rest of the engine compartment, that might look neat too.
For a newer truck, I dont know if conduit would work or not. Depending on how new, the damn thing might have a ton of wires to hide!
Old Feb 29, 2008 | 11:28 PM
  #58
Snowking's Avatar
Snowking
you can get it in a 10 piece bundle each 10 feet long (100 feet) prob take 3 pieces to do a truck.
then all the snap rings slieves, or whatever they are called.
Old Feb 29, 2008 | 11:30 PM
  #59
preppypyro's Avatar
preppypyro
How small of a diameter, do you recall?
Old Feb 29, 2008 | 11:31 PM
  #60
Snowking's Avatar
Snowking
you can get alot of different sizes, I'd assume you'd want 1/2 inch 3/4 inch if alot of wires 1 inch.
