When I bought the car I bought the car, there was no option list as to the power plant as you well know.
The kicker is that when first built in the late 70`s the T had a FORD 428!
But actually what made my ming up to use a GM alternator (supposdly a high performance modiefed thing, I don't really care) is I saw a freshly rebuilt chrome one with a ready made attaching base for a Flathead motor.
Selling on Ebay for 85 bucks.
While the "one wire" alternators work they aren't an ideal setup. The "voltage sensing" wire is hooked directly to the alternators output terminal. So the only voltage that alternator is going to see is 14.4v and it doesn't know anything about the rest of the electrical system. So if you used a faulty or incorrect power wire to the battery, you could easily end up with a loss of 1V. Your battery is then only seeing 13.4v which is just enough to charge the battery and if further load is placed on that power by other accessories, the voltage loss increases further. At this point you are just running on the battery reserves and to the alternator it thinks everything is fine as it's sees 14.4v.
Now where the 2/3 wire alternators are better is, the "voltage sensing" wire is hooked directly to the main battery feed. So if we use the same scenario as above, the alternator will actually increase it's voltage output to compensate for the voltage loss and it also works in reverse. So if there is little load and you have a full battery is will decrease it's power output thus increasing alternator life and decreasing engine load.
The stock generator setup used 3 wires and wasn't a problem but an alternator can only have 1?
please no debates...we know where that went last time... good info though...as always, my choice would be to stick with ford parts if its a ford truck...
