Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Wiring
Old Feb 28, 2008 | 09:49 PM
preppypyro's Avatar
preppypyro
Ahh I getcha. Well regardless man Im sure its gonna end up pretty cool.
Old Feb 28, 2008 | 11:04 PM
Dustin1690's Avatar
Dustin1690
Yeah i agree sounds like a good plan....
Old Feb 29, 2008 | 02:39 AM
Snowking's Avatar
Snowking
Somethings are def. cooler then others. I might as well bring up most alternator swaps for old Ford trucks use a genuine quality GM made alternator. (they are not as big and ugly as Ford setups)
Old Feb 29, 2008 | 05:44 AM
96sherm's Avatar
96sherm
Originally Posted by Snowking
quality GM made
sorry, but those words should not go together!!!
Old Feb 29, 2008 | 08:18 AM
51dueller's Avatar
51dueller
The GM and Ford alts are the same size. An alt looks like an alt. Everyone uses the GM ones because they can get them chromed and the "one wire" option. The one wire alts aren't as good as the 2/3 wired ones.
I guess I'll just use my ugly 130 amp 2 wire 3a Ford alternator.
Old Feb 29, 2008 | 09:47 AM
preppypyro's Avatar
preppypyro
So you cant get a ford alt chromed??
Old Feb 29, 2008 | 02:47 PM
effie_man's Avatar
effie_man
most use the gm alt for the one wire feature as it cleans up the engine compartment just a little bit and its super easy to hook up. I myself will prolly go with it once i need to change from the generator
Old Feb 29, 2008 | 03:27 PM
preppypyro's Avatar
preppypyro
Well it sounds like a good choice for convenience sake.
Old Feb 29, 2008 | 04:14 PM
Snowking's Avatar
Snowking
Its just the standard and prettist to use, guess better wording. Remeber the reson why flatties are purdy is the absence of excess wire.
Actually more Chevy parts fit flatheads and Y blocks then newwer Ford parts. Kinda funny. example would be Y blocks can use modiefied SBC headers. Flathead motors use the same thermostat as a SBC or 318 Chrysler. Oil filter is a John Deere (kinda)
Old Feb 29, 2008 | 04:16 PM
effie_man's Avatar
effie_man
and dont forget the lack of valve covers
Old Feb 29, 2008 | 04:19 PM
Snowking's Avatar
Snowking
I like that aspect to. I'm guessing someone is going to bring up Arduns have valve covers.... hehehe. But it's not a valve cover if it houses spark plugs.
Old Feb 29, 2008 | 04:23 PM
Fomoko1's Avatar
Fomoko1
Actually more Chevy parts fit Flatheads and Y blocks then newer Ford parts. Kinda funny. example would be Y blocks can use modified SBC headers.
How much of a modification is it to use sbc headers on a Y-Block?
Old Feb 29, 2008 | 04:27 PM
  #28
Snowking's Avatar
Snowking
it is the spacing for each exhaust port need to be made smaller or wider I can't remeber.
Old Feb 29, 2008 | 04:54 PM
  #29
Snowking's Avatar
Snowking
At least it will match the 302 very well....
Old Feb 29, 2008 | 04:59 PM
  #30
Fomoko1's Avatar
Fomoko1
To me, neat 302/351/390 engines, neat Ford alt`s....It`s the gm alt`s that are fugly....
