Head Gasket Leak
Old Feb 28, 2008 | 08:02 AM
reblyn's Avatar
reblyn
Head Gasket Leak
Can you please tell me what the symptoms of your head gasket leak were before you were correctly diagnosed? It seems that it often is not obvious.
Old Feb 28, 2008 | 08:21 AM
20046.0PSDX's Avatar
20046.0PSDX
My truck had a general feeling of sluggishness. It just didn't have the usual kick. Also, the degas bottle always showed signs of weeping and after a hard run would really leak coolant. Eventually I started to hear a whistling sound from the engine bay and it was pressure escaping the degas. Mine was bad so my symptoms may be worse than most. Good luck.
Stay Tuned
Amp
Old Feb 28, 2008 | 12:04 PM
Kusto's Avatar
Kusto
reblyn - I see you are new here, but if you try doing a search and reading the hundreds of posts on here regarding that same topic, I'm sure you will become well informed on the subject. Here are some of the most recent links for you. Try the search feature, you will be surprised at what you will find. Some of the threads will list the actual links to the TSBs. I suggest you print a copy and take it in with you so they will be able to tell that you know what you are talking about and they won't be able to jerk you around.
https://www.ford-trucks.com/forums/7...nder-load.html
https://www.ford-trucks.com/forums/6...lant-loss.html
https://www.ford-trucks.com/forums/7...me-puking.html
https://www.ford-trucks.com/forums/6...his-sound.html
https://www.ford-trucks.com/forums/6...-question.html
https://www.ford-trucks.com/forums/6...d-gaskets.html
Just for starters, then there is this....21 pages in the search results.
https://www.ford-trucks.com/forums/s...earchid=355549
Johnny Be Cool
17
Apr 3, 2016 10:11 AM
shillinghillf600
Large Truck
Apr 27, 2014 07:55 PM
kfcoltn
May 21, 2009 02:41 PM
fishin machine
15
Feb 2, 2008 07:39 AM
ksvtwin
1983 - 2012 Ranger & B-Series
Oct 11, 2006 09:03 AM
