Starting problems
Old Feb 29, 2008 | 10:15 AM
Turbodiesel600's Avatar
Turbodiesel600
Originally Posted by Smokin'
If its doing it HOT or COLD, it's not the GPR. How many cranks are we talking about here?
About 8 to 10 before you hear it try to fire. Another 3 or 4 before it actually starts.
Only replaced the bad one. The other load tested good. Why? It is turning over quick and strong now.
Old Feb 29, 2008 | 11:12 AM
rbaker6336's Avatar
rbaker6336
normally when you need one battery you need two
just thinking with one old battery being borderline if you still have an mperage problem
guess you could do a test by putting jumpers on the old battery and see if things change
Old Feb 29, 2008 | 12:12 PM
Turbodiesel600
I'm a little bit confussed. I replaced the bad battery, but the other load tested good. It now turns over fine. Strong and quick. The problem I am having now is that it does not start firing until about the 8th to 10th turn over. It doesn't actually start until the 12th to 14th turn over. Would not replacing both batteries at once cause this?
Old Feb 29, 2008 | 12:36 PM
Smokin''s Avatar
Smokin'
Smokin
I had to learn this one from experience. With a diesel (especially the strokes from what I hear) it can SEEM like its turning over fast enough to start (if you're used to gassers) but it's actually not. The starter has to turn the motor at a high rate of speed in order to build up enough compression to ignite the fuel (you EXPERTS chime in to correct my understanding of general diesel science).
Do you have access to something that can capture audio, so we can listen to it and go from there?
Old Feb 29, 2008 | 12:43 PM
rbaker6336's Avatar
rbaker6336
it can be spinning what sounds to be fast enough but if the electronics aren't getting proper voltage it won't start
Old Mar 2, 2008 | 09:50 AM
MTDewX's Avatar
MTDewX
what about a clogged Fuel filter? just a thought
Old Mar 4, 2008 | 08:37 AM
Turbodiesel600
Sorry about the delay, busy weekend. That info helps. My dad replaced the batteries in his diesel a couple of months ago. I'll pull one of those out and drop it in to see if it makes a difference. I don't know if I have a way to get an audio sample. I can try though. My brother in law borrowed it Saturday to pull a cattle trailer. I will have to do that when he brings it back. Probably be tomorrow.
Old Mar 4, 2008 | 08:38 AM
Turbodiesel600
I just replaced it about two weeks ago. I went ahead and did it when I was fixing the leaks on the filter housing.
Old Mar 5, 2008 | 12:21 PM
Smokin''s Avatar
Smokin'
Smokin
Let us know if that fixes it.
evansz95
Aug 31, 2014 07:43 PM
F150Poke
1997 - 2003 F150
Oct 12, 2012 10:06 PM
shmeek
Jul 12, 2010 08:23 AM
Ford79
13
Jan 30, 2009 06:04 PM
whitesdford
Jan 10, 2008 08:24 PM
