I had to crank a while on my truck today to get it to start as the gpr is going out, but now it developed a problem. I never cranked on it more than 20 seconds at a time without letting things cool down a bit. Now, today when i turn the key to start, nothing happens. All the lights are on, etc, but no glow plug relay (led in cab) and no cranking. Turn the key switch back on and try it, still noting and still no gpr light. Try it again, and everything works fine, the relay light comes on, and it cranks over and finally starts.
Okay, cleaned all the cables, made sure everything is tight, etc, still doing this. I noticed today, that if I held the key in the start position, after about 10 seconds, it started cranking? Is this a relay issue, or a starter issue, or key switch issue?
