Code P2285 Help!
Old Feb 26, 2008 | 04:10 PM
tonlass's Avatar
tonlass
Code P2285 Help!
My 2003 6.0 Is Idleing Up And Down All By Herself When I Let Off The Throttle. Not All The Time But Recently More, Also Cel Came On So I Stopped At Autozone And Got This Code P2285 Injector Pressure Or Someting Like That. Are These Two Related? Please Help
Old Feb 26, 2008 | 04:30 PM
jim6liter's Avatar
jim6liter
My truck set a P2290 (similar code) right before the HPOP went out. Prob.want to bring her in to the dealer.
Old Feb 26, 2008 | 06:05 PM
npccpartsman's Avatar
npccpartsman
ICP sensor under the turbo on the HPOP--get the sensor and the wiring harness pigtail. It usually starts leaking oil and ruins the harness connector. Pretty common with an 03
Old Feb 26, 2008 | 08:41 PM
tonlass's Avatar
tonlass
Thanks guys, I called the dealer, they also seem to think it is the icp sensor, its covered by my 5 year/100k mile warranty which expires next month, so I guess its better now than later!! She's goin in Thursday.
Old Feb 26, 2008 | 08:50 PM
doubledee715's Avatar
doubledee715
make sure you state that you want the wiring harness replaced along with the sensor regardless of whether it has oil on it or not. that's what I would do. fwiw, mine went at 79k. 82k right now.
Old Feb 26, 2008 | 08:59 PM
tonlass's Avatar
tonlass
Thanks doubledee, good call I will be sure to have the tech replace the whole assembly. It's an early 03, and this is really the only problem I've had other than the typical crappy Ford ball joints, had those replaced with Moog greaseables. I have to say I baby her though.
Old Feb 26, 2008 | 09:37 PM
doubledee715
time to stop doing that!! lol
Old Feb 26, 2008 | 11:51 PM
DMH's Avatar
DMH
they started putting the ICP on the right valve cover in 04. Got mine replaced last month on my 03 6.0 liter. $100 diesel warranty cost even though there was a TSB on it... techy said that the ICP itself was redesigned but I never did see the two to compare.
Brian460
Mar 9, 2015 08:56 AM
Regulator1988
Apr 26, 2012 07:49 AM
grantpage
Sep 17, 2011 03:45 PM
rocky1074
Jul 15, 2011 06:24 PM
BMXdad
Jan 5, 2010 11:18 AM
