Code P2285
Old Jun 27, 2011 | 09:55 AM
rocky1074's Avatar
rocky1074
Code P2285
I starter my truck this morning went to go forward and truck stalled. It started right up and CEL came on. Checked code with reader came up with P2285 (Injector CNTRL Pressure Senser CKT) What is this telling me???? Thanks
Old Jun 27, 2011 | 09:58 AM
embry1123's Avatar
embry1123
high pressure oil problem. Could be intermittent/temporary issue. Check your ICP sensor? Hows the oil condition and level?
Old Jun 27, 2011 | 10:14 AM
rocky1074's Avatar
rocky1074
Oil was changed on 6/03 only put about 200 miles since than. Checked oil level which is good.. I cleared code and it did not come back on as of yet...
Old Jun 27, 2011 | 10:32 AM
embry1123's Avatar
embry1123
do you have a means to check the ICP and or IPR valve values? I use AutoEnginuity but I understand they can also be checked using ScangaugeII.
Old Jun 27, 2011 | 11:44 AM
JESTERxHEAD's Avatar
JESTERxHEAD
Are you leaking oil off the back of the motor? If so its more than likely a failed ICP sensor...Since yours is an 03 the sensor is under the turbo, next to the IPR valve. Its a fun one to replace.
Old Jun 27, 2011 | 11:59 AM
rocky1074's Avatar
rocky1074
No oil leaks..Yes I know how much fun it is to replace. I've been there done that when I reconditioned my turbo...
Old Jun 27, 2011 | 06:17 PM
npccpartsman's Avatar
npccpartsman
P2285--ICP circuit short to ground or open defective sensor. Being that it's an 03 I'd say sensor. Do you have any surging? If it's not you might check the wiring.
Old Jun 28, 2011 | 01:39 AM
rocky1074's Avatar
rocky1074
No Surging!!! Since I cleared the code is has not happened again. I will see if I do get a code again and take it from there. Thanks for reply..Rocky
Old Jun 30, 2011 | 09:04 AM
casey.phibbs's Avatar
casey.phibbs
Surging
I also got the p2285 code and notice some surging when i was driving on the highway yesterday. You think it the ICP sensor?
Old Jun 30, 2011 | 02:27 PM
npccpartsman
I would bet on it since your truck is an 03.
Old Jul 15, 2011 | 06:05 PM
rocky1074's Avatar
rocky1074
Installed new ICP Sensor and Connector. No more P2285 Code & Surging....Thanks To All
Old Jul 15, 2011 | 06:24 PM
BLADE35's Avatar
BLADE35
thanks for posting the fix to the problem it realy helps others down the road
Jacob Gervais
Jul 11, 2016 02:47 PM
B846B
Apr 1, 2013 11:29 AM
paulmdahle
Mar 18, 2008 06:10 PM
sparky572
Mar 27, 2007 06:57 AM
03KingRanchF250
Nov 15, 2006 03:30 PM
