p2285, random surging...
Old Sep 8, 2011 | 09:16 PM
grantpage's Avatar
grantpage
From what I read the icp sensor is bad, how would I know if the harness is bad? The "check engine" light is not on all the time, but the code p2285 has been pending for a while.
Old Sep 8, 2011 | 09:22 PM
bismic's Avatar
bismic
Disconnect the harness from the sensor. If its chaffed or oil soaked, replace it (along w/ the sensor).
I assume your ICP is behind the turbo?
Old Sep 8, 2011 | 09:26 PM
grantpage's Avatar
grantpage
I think it is behind the turbo, I just bought the sensor, I have not looked in to replacing it yet. I am hopeing the turbo does not have to be removed.
Old Sep 8, 2011 | 09:43 PM
m-chan68's Avatar
m-chan68
The turbo does not need to be removed to access and replace this sensor.
Old Sep 8, 2011 | 09:47 PM
bismic's Avatar
bismic
The Tech Folder is your friend!
Old Sep 11, 2011 | 12:02 PM
grantpage's Avatar
grantpage
I have everything torn down to the sensor, should I cut a 1 1/16 socket down to fit the sensor, or cut a wrench in half?
Also the plug is oil soaked but the contacts look good, should I just clean and reuse?
Old Sep 12, 2011 | 03:45 PM
Tim C's Avatar
Tim C
I just cut a wrench in half for mine. Just put my second replacement sensor on my truck. First set a code and leaked, I replaced the sensor and cleaned the connector with electrical contact cleaner. It worked for 80000 miles then while towing on a trip in august that sensor started spraying oil. I had to put 6 quarts in over 600 miles to get home. I just cleaned the connector again. If you can get the wiring pigtail I'd replace it though for piece of mind. I didn't have time to wait on the connector to be ordered since my truck is my daily driver.
Old Sep 13, 2011 | 04:08 PM
grantpage's Avatar
grantpage
Thanks, the job is complete, I ended up making a socket. I bought an $8 1 1/16 deep socket from the store and took it to the bench grinder, I shortened it about 1/4 in and ground down the top of it to clear the heat shield, worked great for me. The connector was oil soaked so I cleaned it with carb cleaner and compressed air. So far so good.
Old Sep 16, 2011 | 06:41 AM
Tampa250's Avatar
Tampa250
Were you able to replace the sensor without removing all the things I keep reading about? I have my sensor in hand and need to knock this out in the morning- mine's been hinting at trouble for awhile and recently has gotten bad. I'm getting a good amount of surging now.
Thanks...
Old Sep 16, 2011 | 06:51 AM
npccpartsman's Avatar
npccpartsman
Thanks...
No need to remove much of anything. Here's a great write up: https://www.ford-trucks.com/forums/8...ml#post7693493
Old Sep 17, 2011 | 03:45 PM
grantpage's Avatar
grantpage
That is actually the same write-up I used. The job was not nearly as bad as some people made it out to be. Removing the degas, and computer is very easy, just a few screws on each, nothing technical. I believe that buying the cheap 1 1/16 deep socket and grinding it down to fit past the heat shield works great, some others prefer cutting an 1 1/16 wrench in half and using that. Using the short piece of 3/8 fuel line worked great and getting the new sensor started back in the hole. Either way I would say just dive in to it and get it done.
The truck has to be completely cooled down, or you will come out with some serious burns!
Salts
Apr 24, 2014 09:39 AM
fixxxer-upper
May 30, 2013 12:21 AM
twom7
Nov 11, 2012 08:16 PM
jasonearly997.3
May 9, 2012 07:37 AM
jas88
Jun 28, 2011 08:49 AM
