My 2003 6.0 Is Idleing Up And Down All By Herself When I Let Off The Throttle. Not All The Time But Recently More, Also Cel Came On So I Stopped At Autozone And Got This Code P2285 Injector Pressure Or Someting Like That. Are These Two Related? Please Help
ICP sensor under the turbo on the HPOP--get the sensor and the wiring harness pigtail. It usually starts leaking oil and ruins the harness connector. Pretty common with an 03
Thanks guys, I called the dealer, they also seem to think it is the icp sensor, its covered by my 5 year/100k mile warranty which expires next month, so I guess its better now than later!! She's goin in Thursday.
make sure you state that you want the wiring harness replaced along with the sensor regardless of whether it has oil on it or not. that's what I would do. fwiw, mine went at 79k. 82k right now.
Thanks doubledee, good call I will be sure to have the tech replace the whole assembly. It's an early 03, and this is really the only problem I've had other than the typical crappy Ford ball joints, had those replaced with Moog greaseables. I have to say I baby her though.
they started putting the ICP on the right valve cover in 04. Got mine replaced last month on my 03 6.0 liter. $100 diesel warranty cost even though there was a TSB on it... techy said that the ICP itself was redesigned but I never did see the two to compare.
