MadVan PCM Numbers
Feb 25, 2008 | 06:52 PM
MadVan PCM Numbers
A day or two back MadVan noted different locations to observe the PCM numbers, On the PCM, On the side of the PCM plug inside the engine compartment and possible a small white sticker on the door that also may have the PCM number.
In addition to the above locations, MadVan noted a list of PCM numbers that would more than likely be the number of the PCM.
It is this list of numbers that I'm trying to locate.
So......if MadVan is reading this could you please publish those numbers again? (I know that you are reading this thread)
As always, thanks in advance,
Rog
Feb 25, 2008 | 06:53 PM
Feb 25, 2008 | 07:31 PM
Feb 25, 2008 | 07:34 PM
Quote:
Originally Posted by MADVAN
Cripe ,,,I could have done that
Feb 25, 2008 | 07:36 PM
Quote:
Originally Posted by Action4478
Figured i would take the heat
LLIB
Feb 25, 2008 | 07:38 PM
YBTO ?.....
Is that better than a TDE1 ?????
Feb 25, 2008 | 07:45 PM
If there is one thats better than the best of the worst,,,I want one ....
Feb 25, 2008 | 07:46 PM
YBTO ?.....
MAN6
Have no info on YBTO--its a earlier code.
TDE1 with chip massage best so far.
Bill
Feb 25, 2008 | 07:48 PM
MAN6
No info on YBTO
Bill
Just jurkin your chain,,, I figured it was a cali.....
Feb 25, 2008 | 07:50 PM
Thus the MAN6 or even a MAN5 code
Bill
Feb 25, 2008 | 07:52 PM
Bill
Is it a cali?....
Feb 25, 2008 | 07:56 PM
Is it a cali?....
No N.Y.
MANual6 or 5
Bill
Feb 25, 2008 | 07:58 PM
I like the 94 manual code! Must be named after me!
No N.Y.
MANual6 or 5
Bill
Very funny ....Your build ?.....
Feb 25, 2008 | 08:11 PM
I have a BAOT6???
(Beats All Other Trucks???) 6th revision
-Robb
