MadVan PCM Numbers
Old Feb 26, 2008 | 12:05 PM
  #31
kawa's Avatar
kawa
Bill:
The sticker on the drivers door Indicates: 7-90P at the bottom of the sticker is: F7AE-6Eo61-TKA
I can not find anything further.
Rog
Old Feb 26, 2008 | 12:17 PM
  #32
ono_55's Avatar
ono_55
Originally Posted by kawa
Bill:
Rog
thats the same sticker i have on my truck.
Old Feb 26, 2008 | 12:34 PM
  #33
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Im a little confused, my truck has the NAW4 (96 auto) and I bougth one (in e-bay) for spare that is TEE5 (95 auto), can I use this one if mine goes south? or I have to reflash it or if I tell to TW the code, he reflashes it? or what´s the deal?
Old Feb 26, 2008 | 12:40 PM
  #34
tjbeggs's Avatar
tjbeggs
you can use the TEE5 with out any problems. Not sure if you chip will work with it though. Ask tony but either way the PCM could be reflashed.
Old Feb 26, 2008 | 12:57 PM
  #35
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thanks TJ, Ill ask TW if he burns the chip for the NAW4, and if I change to the
TEE5, he has to change something? Thanks again
Old Feb 26, 2008 | 01:32 PM
  #36
MADVAN's Avatar
MADVAN
NAW4 and TEE5 are the same family. Your chip should work in both.
Bill
Old Feb 26, 2008 | 01:40 PM
  #37
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Merci beaucoup MADVAN for the input.
Old Feb 26, 2008 | 01:42 PM
  #38
MADVAN's Avatar
MADVAN
Bill:
Rog
Rog
MME?---8 revs on the code
I cannot find any info on this #F7AE-6Eo61-TKA
Maybe 98-15-01 was done? Iam in the dark on this one.
Bill
Old Feb 26, 2008 | 02:16 PM
  #39
kawa's Avatar
kawa
Bill, Rep's sent your way.
Rog
Old Feb 26, 2008 | 03:26 PM
  #40
kawa's Avatar
kawa
Originally Posted by MADVAN
Rog
Check this also.
Cadillac Battery Water
Bill
Bill, you of all people should know that "Cadillac Battery Water" is the: "Snake Oil for all Diesels" It is the "Ultimate Power Performer".
It never needs checking.
Rog
Old Feb 26, 2008 | 04:03 PM
  #41
Action4478's Avatar
Action4478
Rog
& you drian it through the kannutin valve , right next to the hefter shaft,under the bullpin....
Old Feb 26, 2008 | 04:42 PM
  #42
kawa's Avatar
kawa
Correction:
It is the "Wiggly Pin" on the "Wobbly Shaft". The "Heftner Shaft" and "Bullpin" were the old models and have been upgraded. (see above)
Rog
Old Feb 26, 2008 | 04:47 PM
  #43
MTNWOODY's Avatar
MTNWOODY
On the PCM Plug inside the driver's wheel well I was able to read MME2 using a butterknife as a mirror (I put it right back in the drawer, don't worry honey). '97 Cali Automatic. Yep.
Old Feb 26, 2008 | 04:50 PM
  #44
Action4478's Avatar
Action4478
Correction:
Rog
And I bet you still have summer air in the tires, too.....
Old Feb 26, 2008 | 04:59 PM
  #45
MADVAN's Avatar
MADVAN
Thats not good for MPG!
Bill
