MadVan PCM Numbers
Old Feb 25, 2008 | 08:15 PM
Todd525's Avatar
Todd525
Is there a pcm number that works better for the 95s??? I have a dually that I am trying to get PAST par to excellent. I assume that I can get it reflashed at the stealership?
Old Feb 25, 2008 | 08:17 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by Robbgt
I have a BAOT6???
(Beats All Other Trucks???) 6th revision
-Robb
not yet you don't!!
Old Feb 25, 2008 | 08:19 PM
Robbgt's Avatar
Robbgt
Originally Posted by tjbeggs
not yet you don't!!
Haha, Tim, even with the TW chip, truck will be in the lower half of trucks here in the speed department... still got STOCK turbo, STOCK HPOP, STOCK trans.... trucks wicked stock... just need more $$$$ well see how that TW chip does... put her through 'er paces!!
Almost forget... stock injectors!... for now...
I still like it though!!!
-Robb
Old Feb 25, 2008 | 08:24 PM
tjbeggs's Avatar
tjbeggs
hey what is tony Charging you for the reburn. I think he told me $150 but I was unsure if that was for 6 positions or not.
Old Feb 25, 2008 | 08:26 PM
Robbgt's Avatar
Robbgt
Ya $150 for 6-position. Can't wait to get the thing out and back. If i put it in and fixes my trans shift problem gone to have a grin from ear to ear!
-Robb
Old Feb 25, 2008 | 09:03 PM
MADVAN's Avatar
MADVAN
Tj
I believe all the PCM's new/rebuilt available (cardone ect) 97 down, auto, 49state, only come TDE1. All other codes are obsolete now. Is this true?
Bill
Old Feb 25, 2008 | 09:17 PM
tjbeggs's Avatar
tjbeggs
I don't know. Never had to replace an OBS PCM for a customer or myself. I would assume that to be true. Ford will only program them for the latest code which would the TDE1 if its an auto.
Old Feb 25, 2008 | 09:21 PM
MADVAN's Avatar
MADVAN
Ya. I think it was over 1 to 2 years ago. Maybe even longer.
Bill
Old Feb 25, 2008 | 10:03 PM
kawa's Avatar
kawa
First of all....THANK YOU MadVan Bill for that "LINKY" it will help prove that I am not as dingy as you have thought. It verify's what I asked you a month or so ago.
After you click on the link there is a box in the upper left corner for further use in other areas. Click on "Trouble Spots" Then Click on:
"Technical Service Bullitins (TSB's)" Then click on:
"Driveability/Fuel/Ign/Etc" Scroll down to Mid-page to:
"Malfunction Inicator Lamp"........Read, then click on (98-15-10)
All of what they are talking about is exactly what I have been fighting with for what seems like forever.
Do you recall me asking if there was a chance that those four (4) codes, P-1391, P-1393, P-1395, and/or P-1396 could be burned into memory??? Well according to this it appears that they can.
What do you think? Now how do I handle it?
You have just moved to the top of my Guru list.
Rog
Old Feb 25, 2008 | 10:31 PM
IDMooseMan's Avatar
IDMooseMan
If I'm reading the chart correctly, my "Calibration 7-90A" relates to the TDE1, right? So...I don't need to get my PCM reflashed?
Old Feb 25, 2008 | 11:15 PM
MTNWOODY's Avatar
MTNWOODY
Originally Posted by MADVAN
Great link Bill. Reps sent. FYI, the guy that put that list together for Diesel Power is the guy doing the custom tunes on the Edge products. Bill Cohron of Power Hungry Performance....my reject Evo should be done and and on its way back tommorrow.
- Ish
Old Feb 26, 2008 | 06:14 AM
MADVAN's Avatar
MADVAN
Rog
If 1 of the 4 PCM's is the 1 you have, get it flashed for the repair.
You have nothing to loose. Print the TSB and give it to them.
Check this also.
Cadillac Battery Water
Bill
Old Feb 26, 2008 | 07:29 AM
  #28
Action4478's Avatar
Action4478
Tj
Bill
Thats what ford told me quite a while ago,, not sure if true ,,,,(B O T W )
Old Feb 26, 2008 | 07:47 AM
  #29
bkcowboss's Avatar
bkcowboss
Jody reflashes PCM's, I would call him and find out what he thinks, you can get the link to his number from the DP tuner site, and he does it cheaper than the local dealership in my area would do it.
plus you can get a tune flashed on at the same time I think.
Old Feb 26, 2008 | 08:00 AM
  #30
MADVAN's Avatar
MADVAN
Yes. Jody's tune will base off the TDE1.
Any rebuilt or new 202 PCM's will be TDE1 as Rick states.
This is as i know of it. True/false unknown for shure.
Bill
