Computer Chips & Tuners
chip/programer???
Old Feb 27, 2008 | 01:42 PM
Layed Out 100's Avatar
Layed Out 100
I just sent them an e-mail asking about that, waiting for a little while before I call. I hope my truck turns out to be set up with a safe tune becouse it is fun to drive the way it is!
Old Mar 1, 2008 | 11:17 PM
Power_Hungry's Avatar
Power_Hungry
Former ******
Originally Posted by ReAX
I really hope someone didn't put a hard chip on your truck. The hard chips plug into the PCM and are usually taped down to prevent them from walking out. Your PCM should be behind the emergency brake and you should be able to see any add ons to it.
If you have a tune installed, it's written over the stock program on the EEPROM and is not a visible feature.
You may want to call them first. The diesel's aren't really OBD2 like the cars are mandated to be and the shop may not be able to communicate with your PCM.
ReAX,
You must've missed it. The key here was "2005". Programmer only...
Also, any Ford Power Stroke since 1994½ as been fully OBDII compliant as per EPA Regulations. Any OBDII scan tool should be able to read the PCM Information and monitor standard PIDs.
The problem here is that no scan tool is going to tell you if the PCM is modified. The only way to do that is actually read the contents of the PCM and compare it against a known valid stock calibration. The only exception is in the off chance that the PCM sets a P0605 (ROM Error) DTC which is a dead giveaway of a modified calibration.
If you want to make 100% sure your PCM is stock, have the Ford dealer update it.
Bill
Old Mar 1, 2008 | 11:27 PM
ReAX's Avatar
ReAX
I am under the understanding that the EEPROM programming is similar to OBD2 but because of the weight of the superduties is not expressly covered under OBD2 legislation. Did this change in 05?
Old Mar 1, 2008 | 11:40 PM
Power_Hungry
Former ******
All vehicles supporting OBDII CAN communications are bound by specifc SAE communications protocols. This means that ANY OBDII compliant vehicle's PCM must communicate with any OBDII scan tool.
ODBII J1850 protocol (the earlier specification) was not as defined and could vary slightly from manufacturer to manufacturer. However, as far as Ford is concerned, ALL 1996 and later (1994½ and later F-Series PSDs) were able to communicate through the same protocols. The switch to CAN in 2003/2004 has made things simpler for the diagnostic tools industry since it is a much more documented and better structured communications specification.
One other thing to remember... Since an F250 is still under the control of "Light-Duty" vehicles, it must adhere to the same OBDII specifications as cars and gas trucks.
Hope this helps.
Bill
Old Mar 1, 2008 | 11:55 PM
ReAX's Avatar
ReAX
Yep, I forgot that CAN made things different. Not having one, I don't think about it unless I want to brag about how much easier it is to swap the radio.
Old Mar 3, 2008 | 10:18 AM
Layed Out 100
Thank's for all the help guys, now I'm lost...sorry...haha.. I am new to all this and don't understand all the big words you have used. I have been driving it for a few days now and love the power and don't really want to change anything plus it says that I'm getting 17.2 mpg average. with a fuel mpg that seems to be pretty good and horsepower thats unbelievable, I am very happy! I guess I just wanted to know what it has loaded on it just in case its something that would tear up the clutch or transmission.
powerstroke cowboy
Dec 18, 2011 11:37 PM
99F350bigorange
Sep 26, 2010 09:35 PM
Dwinn
Dec 8, 2003 02:23 PM
