timing question
Old Feb 23, 2008 | 10:42 PM
albung's Avatar
albung
timing question
Is it possable to be 180 out on dizzy when just replacing a timing chain???
Old Feb 24, 2008 | 07:51 AM
86caprirs's Avatar
86caprirs
No. It is impossable.As long as the 2 dots line up on the crank sproket and the cam sproket facing each other,you are fine. I have seen people put it in wrong and mistake a mark on the cam sproket for a timming mark.
Old Feb 24, 2008 | 07:56 AM
86caprirs's Avatar
86caprirs
Sorry I just read your post again......Yes, you can be out on the timming with the distributor. As long as the chain is installed properly.But if you did not remove the dizzy when you replaced the chain then I can't see that it would fall out of timming.I tink I am really tired right now.
Old Feb 24, 2008 | 11:45 AM
albung's Avatar
albung
Turned out to just be flooded from b4 the chain change clearing up as it runs thanks
Old Feb 24, 2008 | 05:26 PM
mstromni's Avatar
mstromni
If the dist. is timed correctly to the cam, you can't end up 180 degrees off - just a few teeth, if the marks arent lined up. glad you got it runnin
dirty trucker
1983 - 2012 Ranger & B-Series
Sep 12, 2012 07:01 PM
BrettCox
17
Jan 6, 2003 09:25 AM
SPROCKET
Nov 11, 2002 06:18 PM
Varnish
Jun 25, 2002 02:52 PM
beratte
1978 - 1996 Big Bronco
Feb 15, 2002 02:14 AM
