Down pipe & cat delete
Old Feb 23, 2008 | 01:43 PM
firebug's Avatar
firebug
I found a place on the internet that has an aluminized down pipe & cat delete together for 55.56 delivered. It says that it has a 3" ball joint inlet with 3.5" outlet. Is this a good price ? I didnt put the web site name or manu name because I didnt know if thats allowed. Also on fpr mods does anyone have a picture of where th bb goes and where do you get the bb, I know dumb questions, but i'm still learning.
Old Feb 23, 2008 | 01:48 PM
84-250's Avatar
84-250
I cant comment on the dp and cat delete. The fpr mod I can thou. When you remove the cap on the FPR, I believe its 19mm or so. you will see a spring and a trianglely thing the size of a 22 bullet. Normally the spring slips into the triangly thing but now you put the bb in first then the spring. Then reinstall the cap and recheck the fuel pressure.
Old Feb 23, 2008 | 01:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
post the link for the pipe, price sounds excellent
Old Feb 23, 2008 | 01:53 PM
firebug's Avatar
firebug
its at modsfortrucks.com and its the Diamond Eye #124005
Old Feb 23, 2008 | 02:31 PM
c00nhunterjoe
havnt found it yet, but good lord, how can this be a direct fit in our trucks? if so then i am ordering one!
http://www.modsfortrucks.com/product...+Eye%27&d=1503
Old Feb 23, 2008 | 02:39 PM
c00nhunterjoe
ah, i found it, that number is the cat pipe only, the picture is misleading, the downpipe that is direct fit is this one.
http://www.modsfortrucks.com/product...+Eye%27&d=1390
Old Feb 23, 2008 | 10:18 PM
farmert's Avatar
farmert
I got the dimond eye down pipe from Diesel Preformance Products in Dec. for $85. The are a sponsor listed on the left of the page.
Old Feb 23, 2008 | 10:27 PM
firebug's Avatar
firebug
farmert how hard was it to install. I've heard you have to cut part of firewall, flatten a seam on firewall, i dont want to cause any damage that may cause some type of permanent damage to my truck. Does the one you bought come with install directions
Old Feb 23, 2008 | 10:34 PM
bigbadwolfe's Avatar
bigbadwolfe
https://www.ford-trucks.com/forums/7...tion-pics.html LOOK AT THIS RIGHT UP ITS GOT GREAT PICS AND SHOULD HELP YOU WITH YOUR ?S
Old Feb 23, 2008 | 10:54 PM
c00nhunterjoe
its just the seam on the firewall that needs to be flatened, no cutting required and you will never notice the bend
Old Feb 23, 2008 | 11:05 PM
farmert's Avatar
farmert
Hardest part was getting the old one out. A sawsall helps. Just cut the seam in 3 or 4 places and bend it up. There were no instructions with the down pipe.
ramrod7373
May 4, 2010 04:05 PM
1997f350stroker
May 12, 2009 03:32 AM
Mike8623
Jan 5, 2009 09:47 PM
RobertJohn
Dec 26, 2007 01:57 PM
elkarcher
Sep 18, 2007 03:17 PM
