Cat delete pipe
Old May 4, 2010 | 07:50 AM
ramrod7373's Avatar
ramrod7373
Cat delete pipe
Does anyone know where I can get a cat delete pipe for my 95 PSD? Can't afford a whole exhaust right now, so I want to get the cat out of there so it will flow better? After that maybe a new muff. Not sure I want to do the down pipe yet, don't really like the idea of having to massage the firewall to get it to fit.
Old May 4, 2010 | 08:06 AM
ccarrier's Avatar
ccarrier
id def do a downpipe, the firewall modifying isnt hard to do and youll never see it again. they are cheap and effective mod.
and as far as you cat... just go to a muffler shop and have them cut it off and weld a piece of pipe back in its place, itll be cheap
Old May 4, 2010 | 09:46 AM
superduty4x4's Avatar
superduty4x4
Be careful in Cali... I hear they are ramping up the inspections and if you don't have a cat you fail emissions.
Old May 4, 2010 | 10:04 AM
Brown Falcon's Avatar
Brown Falcon
Yes, article in Diesel Power went over all the inspection details for california and a couple other stricter states.
I'd look that up for your county first before a cat delete. They look for tampering of emmissions equipment and do a snap test looking for visible smoke in most places in cali.
IMO you should just gut the cat instead of getting rid of it. Some guys have welded a piece of straight pipe through it but I think it would look modified that way if they inspected it. Better to just get it hot, drop it down, and then knock all the internals out with a crowbar or something.
Then later you can put in a 4" exhaust after the cat or a 4" high flowing cat, and get a straight-through design muffler like a glasspack (i have a 4" glasspack that's only 8" long on mine to pass NC safety inspection)
As far as the downpipe goes, you don't need to massage the firewall much. Cut the body seam and bent it up. Or rent a portapower and bend it a little. I just used a crowbar and a piece of wood to bend it. It'll really help the truck breathe better.
Old May 4, 2010 | 10:40 AM
superduty4x4
Brownie the bad thing with CA is if it isn't CARB certified you fail the visual inspection, so you are extremely limited on what you can or can't install. Even a boost gauge can cause you to fail!
Old May 4, 2010 | 10:48 AM
Brown Falcon
What I read was that diagnostic gauges are allowed, such as boost, egt, trans temp, etc. You can even get away with aftermarket turbos as long as they LOOK stock.
But if you have one of the newer programmers like the Edge CTS that has the gauges built in you can be failed even if you are just using the gauge part of it. They recommend removing any chip you have and taking the programmers out before inspection.
I forget that I get Diesel Power magazine about a month ahead of time with my subscription, but definately get the next issue and read the article about the emissions testing.
Old May 4, 2010 | 11:09 AM
superduty4x4
I have heard stories of guys getting failed because the boost gauge T didn't have a CARB number on it... probably avoided by finding a tech that has a little common sense. So glad I don't have to deal with Cali emissions crap!
Old May 4, 2010 | 11:13 AM
Brown Falcon
Me too. My wife is from southern Cali and I am SO glad she doesn't want to move back there. I'll be back in Oregon next year though. I miss home.
Old May 4, 2010 | 01:11 PM
Midwest Dually's Avatar
Midwest Dually
I remember Cali emissions being a PIA! I lived there for a short while once, and it was a nightmare! I went out and bought a 69 F-100 just to avoid the mess, as anything built prior to 1973 was emissions exempt.
Living here in Az, there are emissions, but I dont know how much issues go with it, as I just moved here and kept my home address in Wy, where there are no emissions. I was curious about switching to plates here, but wanted to get specs on it first. I like the idea of the moddified cat (Brown Falcon) and am considering this as well.. LOL!
Old May 4, 2010 | 04:05 PM
ramrod7373's Avatar
ramrod7373
As far as I know CA is "smog" testing 98 and newer. My 95 shouldn't have a problem, I don't want to run a programmer, so I am going to keep the stack downpipe and maybe do a downpipe back exhaust when I can afford it.
dmncoon
Nov 11, 2008 09:24 PM
RobertJohn
Dec 26, 2007 01:57 PM
elkarcher
Sep 18, 2007 03:17 PM
Craze
17
Jun 11, 2004 09:35 AM
