Cat Delete
Old Feb 23, 2008 | 08:49 AM
JethroF250's Avatar
JethroF250
Cat Delete
Does anyone know how much of a difference it would make to remove the cat? And where can I order one from online for pretty cheap?
Old Feb 23, 2008 | 09:00 AM
Knotwild's Avatar
Knotwild
You don't have to replace anything if you don't want to. I took my cat off and used a crowbar to beat the guts out of it and put it back on. By the seat of my pants, I felt a big difference. By the same token, I put on a 4" exhaust after that and I could not really feel any difference. If you haven't already, you should put in a 3" downpipe. That took me about a half a day.
Old Feb 23, 2008 | 09:03 AM
JethroF250's Avatar
JethroF250
Ok should i weld a tube inside the cat or will it make a diff with sound if i just beat it out?
Old Feb 23, 2008 | 09:08 AM
c00nhunterjoe's Avatar
c00nhunterjoe
for a mostly stock truck just gutting it would be sufficient. there is a slight gain from using a straight pipe design instead of the gutted design. having the gutted cat allows the air to become turbulent as it enters the gutted cat and it doesnt flow as well since it is fighting to get out of the cat and back into the tailpipe
Old Feb 23, 2008 | 09:10 AM
JethroF250's Avatar
JethroF250
makes since a delete pip is like $40 but for now i just want the sound. do you think it would sound the same/worse?
Old Feb 23, 2008 | 09:18 AM
dauto's Avatar
dauto
I cut mine in front of cat and ran straight 4 " pipe to the rear.The pipe from International dealer(Happens to be my closest big truck shop) was about $3.50 or $4 a foot, Needed about 10'.Open pipe does not seem much louder than stock buy runs much better.I cut it and fabricated/welded a slight angle to bring the pipe out behind the rear tire at a angle.
Aug 22, 2012 11:39 PM
zimman20
Oct 14, 2002 08:38 PM
Lemineur
24
Apr 9, 2002 11:58 AM
mwittman
1983 - 2012 Ranger & B-Series
Aug 17, 2001 05:44 AM
Motorcraftsman
Nov 24, 2000 05:32 PM
