Sponsored by: Auxito
payload
Old Feb 21, 2008 | 02:41 PM
ibleedblueoval's Avatar
ibleedblueoval
payload
I have a 99 F150 2wd extended cab. The GVWR is 6050lbs. I don't know how much the truck weighs so I was hoping someone might know the payload off hand.
Thanks
Old Feb 21, 2008 | 07:40 PM
tampa898's Avatar
tampa898
Thanks
Just off the top of my head, I think your vehicle weighs about 4300 lbs. So 6050-4300 = 1750 lbs. In the GVWR you also have to include the load inside the truck, such as yourself and other such items. The more weight in the truck the less payload you have available.
Old Feb 22, 2008 | 10:34 AM
Club Wagon's Avatar
Club Wagon
Sorry, don't have '99 specs in front of me. To pin it down you'd need more details. However for '98, FORD did not even list a "6050lbs" GVWR for an "extended cab" in sales lit. That GVWR appears only in the "REGULAR CAB" 5.4 list. The 6050lbs GVWR 2wd Styleside w/120" wb, 6.5' box had Payload of 1805 lb & the 139" wb, 8' box 1690 lb & 1795 lb for Flareside. They listed 5.4 "SUPERCAB" w/6250 lbs GVWR.
Old Feb 22, 2008 | 12:43 PM
Bobby82490's Avatar
Bobby82490
Go to msn.com under the auto section, it will tell you alot of things like payload, tow rating, hp and torque, etc.
Old Feb 22, 2008 | 01:31 PM
galaxie641's Avatar
galaxie641
If you have the owners manual it will break it down for you. Everything from transmission, engine and body style effect it. But everything other than a Screw should be able to handle up to 2K lbs at short distances at the very least.
Old Feb 23, 2008 | 12:41 AM
Club Wagon's Avatar
Club Wagon
This reminds me of the Good Old Days.
When I was a kid my Uncle had a beat, very early, dark green, F100, dual water pump, Flathead V8. I recall helping him loading it until the springs had gone down to the stops with firewood. He watched carefully, not wanting to overload it beyond that point. Wonder what those loads weighed? Did Mythbusters ever do an Overload segment?
When it absolutely must be moved I don't go that far, preferring to always leave a couple of inches of spring travel on the Econolines I've owned since the 70's. Paying attention to how much the bumper goes down becomes as precise as a spring balance scale once you get familiar with how a vehicle handles.
hsfbfan
2009 - 2014 F150
Jul 6, 2012 02:44 PM
smokewagun
2009 - 2014 F150
Mar 4, 2012 03:30 PM
990rick
Oct 7, 2010 09:53 PM
kjf-250
2004 - 2008 F150
Nov 15, 2009 12:06 PM
///M Puller
May 28, 2008 11:34 PM
