Offroad & 4x4
d60 swap
Old Feb 21, 2008 | 12:56 PM
captain p4's Avatar
captain p4
d60 swap
early 90s d60 into my '78 bronco and I want to keep the radius arms.
where do I get Cs and trac bar mounts? can I use the stock radius arms with the small driveside tube? is the upgrade to cage arms worth it?
annnndd..
go.
Old Feb 21, 2008 | 12:59 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Go look at Cages website and I think JBGs website. They have the C wedges you will need. If Im not mistaken the ball joint 60 is better for coil sprung apps because you dont have to deal with the axle housing. The wider stance of the coil springs will miss. There is plenty of room for the stock radius arms but the Cage arms are cool. $700 though so that usually changes peoples mind.
Old Feb 21, 2008 | 01:36 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
x2......jbg for sure
Old Feb 21, 2008 | 11:10 PM
captain p4's Avatar
captain p4
found the wedges but can't seem to find a trac bar mount on the bronco graveyard, anyone know where I can find one?
will my stock drag link bolt up?
Old Feb 21, 2008 | 11:44 PM
MBBFord's Avatar
MBBFord
Here's some good reading:
http://www.pirate4x4.com/forum/showthread.php?t=561156
If nothing else, you'll get an idea from in there...
Old Feb 21, 2008 | 11:45 PM
captain p4's Avatar
captain p4
lol i just looked through the whole ford section over on pirate and found that thread and posted in it
Old Feb 22, 2008 | 07:22 AM
Big block bronco's Avatar
Big block bronco
Wink
I just swapped a D60 into my 1983 bronco. Drag link lenths are different for our trucks, but i was abe to use a stock drag link, although I have hi steer arms.
I made my track bar mounts and used an adjustable track bar.
I have pics, but I dont know how to insert them.
Old Feb 22, 2008 | 07:57 AM
MBBFord's Avatar
MBBFord
Yeah, if your stock drag link doesn't work, a adjustable one should. I have one, and they seem to be pretty good quality, but a little $$$. I paid a little over $100, but that was about 2 years ago. They're more now... might be able to find one on evilbay.
Old Feb 22, 2008 | 05:33 PM
Big block bronco
Talking
My D60 is from a 1979. It has more room on the driver side to mount the needed hardware. The '90's model will not have room for mounting radius arm tabs.
Old Feb 22, 2008 | 06:27 PM
fishmanndotcom's Avatar
fishmanndotcom
i'm curious to see how you go about mounting this thing. i sold my 88 D60 for a 79 d60 for this very reason. i got my wedges from JBG and they were great. one thing to note if you plan to use your stock clamps you will have to make a 1/2" spacer b/c the D60 is a touch larger than the D44 they were meant for.
the aftermarket arms are purely opinion, they will work flawlessly as i have seen several guys in the bronco club run them. i, however, could not justify that much money!
-cutts-
Old Feb 22, 2008 | 07:18 PM
Big block bronco
I had my 1979 c bushings machined out to fit the larger D60 tube diameter.
Old Feb 25, 2008 | 06:30 AM
kjett's Avatar
kjett
P4,
Have the welder, grinder, and all the stuff needed to fabricate the mounts and put the c's on. If you want, instead of running a stock style "bushing" track bar, we can fab up a heim joint bar and mounts. You just gotta come up with the tube, ends, and tabs, all of which I can get you info on where to get what you need. If you can get the stuff early this week, we can be ready for this coming Sunday to get it done!
Old Feb 25, 2008 | 10:09 AM
captain p4's Avatar
captain p4
Let me know where to get the parts I need if you don't mind. Bronco is not quite ready to make the trip down there, still have to put the new tranny in and pull that 9inch out of the other truck for you, but as soon as its ready I'll let you know.
do you have the tools to make the spacer we need too? I've also heard you can grind out the c wedges so that they're the same width as on the d44 when mounted.
Old Feb 25, 2008 | 10:31 AM
kjett's Avatar
kjett
I can either make the spacers out of 1/2" plate, or I can machine out the c's. It's your choice. Granted, making the spacer would be easier, but then you need to get longer bolts as well and re-mount the way the lower coil bucket sits on top of the radius arms. So in the long run, it would probably be best to just trim out the inner portion of the c's to fit.
As for the tubing and such, contact S&W racecars up in PA. They will set you up with what you need. I'd get the 3/4" x 16 thread, rod ends, a set of their weld in bungs and the 1.25 DOM tubing. You wan work with 4', but I'd get a 5' piece to be sure, and you can always trim some off depending on where you mount your upper and lower brackets.
Old Feb 25, 2008 | 02:57 PM
ns_redneck's Avatar
ns_redneck
http://www.projectbronco.com/Technic...conversion.htm
u can't use the newer ones on it. the radius arms go where the pumpkin is in the way. this article will tell u everything u need. i am starting to do the same thing
good luck
Saber123316
Jul 1, 2010 11:14 AM
kbak
Dec 21, 2006 06:03 AM
MRStace84
Jan 29, 2006 05:15 PM
cjbronco
1978 - 1996 Big Bronco
Oct 25, 2005 12:44 PM
fatdaddy
Jun 29, 2002 08:14 PM
