Changing Radius Arm 4x4
Old Jan 4, 2006 | 12:46 PM
MRStace84's Avatar
MRStace84
Question Changing Radius Arm 4x4
How hard is it to change a radius arm (driver's side) on an 84 F150. Specifcially getting the radius arm loose from the front axle. That's the only part I've never had apart.
Thanks.
Old Jan 4, 2006 | 01:58 PM
big hoss 29's Avatar
big hoss 29
never mind, I thought that you were just replacing radius arm bushings, not the whole radius arm.
Old Jan 4, 2006 | 02:02 PM
MRStace84's Avatar
MRStace84
No, I want to change the whole arm, not the bushings. My truck is lifted, so I have already ground the rivets off, and have grad 8 bolts holding my brackets on. The threaded stud end has a lot of corosion on it, and I am afraid that it will evenutall rust in two. So, I need to change it. The problem is I don't know how to take the arm loose from the front axle.
Old Jan 4, 2006 | 02:12 PM
andym's Avatar
andym
There are two bolts holding the bracket to the TTB arm. One is under the coil spring, so you'll have to take the shock(s) and spring off. The other bolt is underneath and you'll either need a 1/2 stubby air impact or an 8' breaker bar. It is a BEAR to get off. If you have a lot of rust, you're going to need penetrating oil and heat, too.
Old Jan 4, 2006 | 02:14 PM
MRStace84's Avatar
MRStace84
That's what I was afraid of, thanks for the heads up.
Old Jan 29, 2006 | 05:15 PM
MRStace84's Avatar
MRStace84
Just an update in case anyone looking for info finds this thread. I change my radius arm this weekend. Sprayed the bolts, that hold the radius arm to the TTB with penetrating oil, then put a little heat on them with a hand held propane torch, and they came right out. Not to big of a deal at all. However, as I mentioned my radius arm braket and coil spring wasn't any big deal to ge off, since I had removed them not to long ago. I also got my new arm from bronco graveyard.
94xlt150
Mar 9, 2015 06:51 PM
84ford150
16
Jul 10, 2008 01:24 PM
1984F15016
Mar 15, 2005 02:27 PM
badboyina67
Apr 9, 2002 12:40 PM
