radius arm bushings
Old Jun 29, 2002 | 04:32 PM
fatdaddy's Avatar
fatdaddy
radius arm bushings
Old Jun 29, 2002 | 07:59 PM
supercab4x4's Avatar
supercab4x4
radius arm bushings
is it possible to change by just getting the nut loose and sliding the arm forward?let me rephrase that.i did this about ten years ago and did i just get lucky that something didnt come loose and whack me?i think i lifted the truck just a little when i did it.
Old Jun 29, 2002 | 08:14 PM
78CREW's Avatar
78CREW
radius arm bushings
I replaced the rear radius arm bushings on my 78 2wd this weekend. Following a recommendation found on this board, I removed the radius arm bracket from the frame rail. 3 bolts must be removed and the rivet must be ground off, and replaced with a grade 8 bolt during reassembly. The radius arm bolt should be loosened before the bracket is unbolted from the frame. I was able to do each side in less than an hour. It would probably go quicker if you are uninterupted.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
