performance transmission?
Old Feb 21, 2008 | 09:53 AM
jimbob21rc's Avatar
jimbob21rc
Question performance transmission?
i have recently bought and been working on my 78 f100 351w c4 trans. my trans. is already in 3rd gear at 20 mph and has got the motor wound out pretty tight when i am cruising about 55-60 (it sounds really good) but im worried. i want to be able to haul *** and fly, does anyone have any suggestions on what i could do.
Old Feb 21, 2008 | 10:27 AM
masterbeavis's Avatar
masterbeavis
Gear vendors overdrive or put on taller tires in the rear, or change out your third member for some 2.75 gears.
Old Feb 21, 2008 | 10:33 AM
jimbob21rc's Avatar
jimbob21rc
well i don't know much about rear-end gears i have done very little with them. what would 2.75 gears do for me? would it raise my shift points, and should i get an rpm tach to monitor them?
Old Feb 21, 2008 | 12:30 PM
masterbeavis
2.75s will rob your low end grunt, and will make your truck turn less RPM going down the freeway. Typically your transmission will hit third gear at or before 28MPH unless you have the throttle pinned.
ggazz50
Sep 11, 2013 12:04 AM
old blue beast
Jul 9, 2013 06:49 PM
wastingas
Nov 25, 2012 04:24 PM
clhart426
Mar 30, 2012 06:31 AM
redwings
Mar 13, 2005 09:04 PM
