Sponsored by: Real Truck
Trans Fluid Type???
Old Sep 10, 2013 | 10:02 AM
ggazz50's Avatar
ggazz50
Trans Fluid Type???
I have a 2002 SD with a 6.8 engine auto trans. The trans dip stick says Mercon on it. My question is can I put Mercon V in this trans and is it compatible with the Mercon? Also how can I tell what trans I have in this truck? Thanks Gene
Old Sep 10, 2013 | 11:01 AM
bthr22's Avatar
bthr22
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Check this article out. It's written by Mark, one of the members here. Details the process to change fluid, plus what type.
Old Sep 10, 2013 | 05:26 PM
projectSHO89's Avatar
projectSHO89
Current recommendations by Ford for all kinds of stuff (lubricants and fluids):
https://www.fcsdchemicalsandlubrican...n/quickref.asp
Old Sep 10, 2013 | 06:43 PM
Gage2502's Avatar
Gage2502
Question....I have a 2005 Super Duty V10 4x4 Auto Trans and on the trans dip stick it says Mercon SP? Did they use the wrong dip stick on my truck?
I ordered the truck back in February 2005.
Thanks....Gage
Old Sep 10, 2013 | 08:07 PM
Tom's Avatar
Tom
Hi Gene,
Mercon V replaced Mercon a few years ago. Changes were made and they are completely compatible; and Ford doesn't license the production of Mercon anymore. So the only way to ensure that you're getting the proper fluid is to buy licensed Mercon V.
Thanks....Gage
Nope, the dipstick is correct. DO NOT use Mercon V in your transmission. You need Mercon SP(Discontinued) or Mercon LV(Current production).
Old Sep 10, 2013 | 08:14 PM
bthr22's Avatar
bthr22
Is your trans the 4R100, or 5R110?
Old Sep 10, 2013 | 08:17 PM
Tom's Avatar
Tom
The OP has the 4R100, and Gage2502 has the 5R110.
Old Sep 10, 2013 | 09:23 PM
ggazz50's Avatar
ggazz50
Thanks for the info Tom, I really appreciate it. Gene
Old Sep 10, 2013 | 09:36 PM
bthr22's Avatar
bthr22
That's what I thought, thanks for verifying Tom.
acf6's Avatar
acf6
Mercon SP is not discontinued?? I bought a case of it from the dealer a few weeks ago...
Old Sep 11, 2013 | 12:04 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
When I had my trans flushed this past week my dealer also had to double check that I didnt need Mercon SP. The 05 front end always throws them off for about 15-20 minutes. The guy usually crawls under, then gets back out and looks around for a while trying to figure out why eveything is wrong.
KDAVID1
Sep 2, 2016 06:57 PM
fabsroman
Mar 6, 2016 09:08 PM
Headviking
Jul 30, 2011 12:01 AM
