forged or pmr
Old Feb 20, 2008 | 03:37 PM
PlatinumPSD's Avatar
PlatinumPSD
forged or pmr
Ok i know that you can remove a plug on the eng. to tell if the rod is forged or pmr. what i wanted to know is there a date or can i use the vin, if not were is the plug at? my truck is 2001 f-250 truck built 02/01 not know eng build date. but will go look when the rain stops.
Old Feb 20, 2008 | 04:33 PM
wlihntr's Avatar
wlihntr
the cut-off date for the forged rods that has floated around on the net is 10-16-00 (engine build date) so you most likely have the PMR's.
Old Feb 20, 2008 | 04:40 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I guess I am good with build date of 8-19-00.
Thanks for that info.
Old Feb 20, 2008 | 04:50 PM
ron's power stroke's Avatar
ron's power stroke
the engine build date will be a sticker on the driver side valve cover...
Old Feb 20, 2008 | 05:17 PM
PaysonPSD's Avatar
PaysonPSD
Here's a link on how to check for Forged or PMR:
http://www.dieselinnovations.com/gal...g2_itemId=1524
Old Feb 20, 2008 | 05:18 PM
IDPisan's Avatar
IDPisan
Here is a link for locating the inspection hole and some interesting pics of PMR VS. FMR.
http://www.dieselinnovations.com/gal...g2_itemId=5236
Old Feb 20, 2008 | 05:22 PM
IDPisan's Avatar
IDPisan
[QUOTE=PaysonPSD]Here's a link on how to check for Forged or PMR:
http://www.dieselinnovations.com/gal/main.php?g2_itemId=1524[/QUOTE]
Your too quik for me!!
Old Feb 20, 2008 | 05:24 PM
PaysonPSD's Avatar
PaysonPSD
[QUOTE=IDPisan]
But you gave more info. And thanks for that second link.
Old Feb 20, 2008 | 05:54 PM
FordGuy_till I die's Avatar
FordGuy_till I die
Just made it! Sept. '00. for motor, truck is 3/01. Best to pull the plug to verify I guess.
Old Feb 20, 2008 | 06:04 PM
Tenn01PSD350's Avatar
Tenn01PSD350
You better look at it. Mine has build date on engine of Sep 00 and it has PMRs. Built in Indy plant. Some of the later Mexico built ones have forged though so there is only one way to be sure. There is no known for-sure cutoff date that I have seen.
Old Feb 20, 2008 | 06:57 PM
Orezona's Avatar
Orezona
I'm pretty sure I have PMRs but since it was made in Mexico 8/01, I might just take a look this weekend.
Texas Chain Ring
Sep 4, 2012 06:18 PM
homesteader
16
Mar 12, 2010 03:11 PM
PsD007.3
50
May 5, 2009 10:42 AM
travis dasher
13
Jan 27, 2007 12:18 PM
Powerstrokedlariat
27
Oct 19, 2005 10:03 PM
