code 513 koeo
Old Feb 19, 2008 | 08:45 PM
jm ray's Avatar
jm ray
code 513 koeo
i am having a problem with a 94 b400.it is giving a code 513.--ecm internal voltage fault.i can not find anything wrong.grounds seem good. runs ok,but cel comes on in 5 seconds after clearing codes and restarting engine. anyone seen this or know where to start. i did try a used ecm but nothing changed. battery /alt output is steady and normal, at the battery but the voltmeter on the dash is not steady.it flutters a little.anyone seen this before?what is a likey cause of the 513.please help a dummy out if you can.
Old Feb 19, 2008 | 09:46 PM
pawpaw's Avatar
pawpaw
Well I'd consder running this puppy by your favorite autoparts store for a no cost electrical system checkup & load test, via their portable system tester.
Correctly used, it can properly load test the alternator, battery, battery cables & will likely be able to spot the culprit.
Let us know what they find.
Adam_Tinkerer
Aerostar
Nov 15, 2016 08:04 PM
cobra_4
Jan 1, 2016 11:45 AM
F350Centurion
May 16, 2012 11:47 AM
TheTowingCowboy
Jan 15, 2012 09:51 PM
blucollar4xford
Offroad & 4x4
17
Jul 12, 2011 04:04 AM
