The gear shift lever, mounted on the steering column is real loose.<O:p</O:p When it is in park, some times I have to push up on the lever to start the truck.<O:p</O:p
How can I tighten it up?<O:p</O:p
<O:p</O:p I am guessing some screw in the column need to removed to get at something
<O:p
I had it tightened about 5 yrs ago while it as in a shop for some other work..<O:p</O:p
