H2E vs HX50??
Old Feb 19, 2008 | 09:24 AM
tjbeggs's Avatar
tjbeggs
H2E vs HX50??
I know they are similair turbo's but are they the same? Same exhaust outlet flange (downpipe)? Same exhaust inlet? Compressor and Turbine wheels?
Any info you guys can give me would be great. Had a bead on an H2E with 17cm exhaust housing and they went to pull it off the shelf and it wasn't there. Now they have offered a HX50 for the same price.
Old Feb 19, 2008 | 11:44 AM
Hiflyer746's Avatar
Hiflyer746
You don't want either of those turbos without a pretty good injector. Especially with the gears you have and the plow. . . What are you plans?
Tim
Old Feb 19, 2008 | 12:49 PM
tjbeggs's Avatar
tjbeggs
I have a set of stage 2's planned.
Old Feb 19, 2008 | 02:03 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
For stage twos, i would go with a stock H2E with as small of an exhaust housing you can, for plowing. 17cm?
Old Feb 19, 2008 | 05:06 PM
tjbeggs's Avatar
tjbeggs
Kris that is my plan and what I had lined up. but now the place that I was gonna buy the turbo from found out they don't have it any more and have offered me a HX-50 which from everything I have seen says the H2E is the old version of the HX-50 but I can't find any specs to support that. Looks like there are atleast two versions of the 50. but I would atleast like to know if the dowpipe piped connection is the same as thats the only part I am not sure I want to fab up.
Old Feb 19, 2008 | 09:51 PM
PowerstrokeJunkie
HX 50-
the H2E Looks very similar, and i found this on the net-
"It is basically the same turbo as the hx50. I believe the hx50 took over for the h2 series. Do you happen to have pictures of the hx50 particularly turbine section."
Sounds like the HX50 is newer, and if anything, should be the same turbo but "improved". They spool slow, make sure you have a tight exhaust housing. Oh, and the downpipe should be the same thing!
Brettboat
Oct 9, 2014 04:12 PM
1986FordF150I300
20
Jun 1, 2009 09:59 PM
FARM69
23
Dec 8, 2008 01:30 AM
FARM69
21
Jun 13, 2008 06:07 AM
payableondeath6
19
Jul 24, 2007 06:17 AM
