TransGo Tugger Partial Install
Old Apr 8, 2008 | 10:05 AM
  #31
Tenn01PSD350's Avatar
Tenn01PSD350
This is why I drilled mine to the middle ground size. I don't want to be snatching my boat down the road. I figure Jody can up the pressure for my higher HP settings and leave it alone for the tow setting and stock setting. Besides, I have a diode in there, tick tick tick.
Old Apr 11, 2008 | 12:51 AM
  #32
Mr. Bob's Avatar
Mr. Bob
Originally Posted by Tenn01PSD350
How's them 215cc Swamps hybrids treating you? I am particularly interested in the idle quality. Mine don't quite idle to my satisfaction.
Mine idle good. they are a touch shaky, but nothing I would not expect from not having been live tuned.
What is wrong with your idle? What are you running for injectors/tuning???
Old Apr 11, 2008 | 12:58 AM
  #33
jhand124's Avatar
jhand124
I think he is running the same as you. Tenn was getting them injectors live tuned at Smokin by Jody today.
Old Apr 11, 2008 | 08:09 AM
  #34
TurtleRacing's Avatar
TurtleRacing
PSD Addict
OK, I'm coming into this a little late and trying to understand it all, so, I take it this is not purchasing a VB and installing? This is modifying the stock VB? Is there a link to the kit?
And what is the .427-.5 thingy? Something that comes in the kit?
Old Apr 11, 2008 | 08:34 AM
  #35
mueckster's Avatar
mueckster
Ford Lincoln Mercury Reprogramming Kits
Here is link to the Transgo website. The Tugger kit is the first one listed. This is for those with trans out and doing the converter mods also. If you want to do the valve body mods only, you would need the second one listed. There are installation videos for each one. The kits come with a spring for the line pressure modulator valve, but you can get a new valve, with a larger piston, that will not need this spring. The modulator valve allows the computer to regulate the trans line pressure thru this valve. The larger the piston the firmer the shift. I opted to change the modulator valve because of prior experience with it in the sonnax valve and triccumulator mods. This kit just takes this shift mod to a higher level of shift control.
Old Apr 11, 2008 | 08:38 AM
  #36
TurtleRacing
PSD Addict
Awesome explanation! Thanks!
Old Apr 11, 2008 | 10:13 PM
  #37
mueckster's Avatar
mueckster
"This is for those with trans out and doing the converter mods also." Meant to say "pump mods" in my post (#35). Sorry for any confusion this may have caused.
Old Sep 11, 2009 | 04:50 PM
  #38
74baja's Avatar
74baja
Hey all,
Sorry to dig up an oldie, but I just got a Transgo HD2. I know I have to do the calibration plate and the accumulator VB mods, but I still don't fully understand the line pressure modulator valve. Does my kit come with what I need to go to .500, or do I need to get something else? Is it really worth it, or should I just install what I have with the kit?
Thanks
Old Sep 11, 2009 | 04:54 PM
  #39
Izzy351's Avatar
Izzy351
Just do the kit. You'll really like it!!
Old Sep 11, 2009 | 04:56 PM
  #40
74baja's Avatar
74baja
So I can get at the line modulator after taking out the accumulator VB?
Old Sep 11, 2009 | 05:10 PM
  #41
Izzy351's Avatar
Izzy351
I just did the kit and didn't screw with that. They are plenty firm after the tuning update to match. Are you running any tunes now?
Old Sep 11, 2009 | 07:32 PM
  #42
Tenn01PSD350
https://www.ford-trucks.com/forums/738064-transgo-e4od-hd2-d-install-article-4.html
Old Sep 11, 2009 | 08:00 PM
  #43
Izzy351's Avatar
Izzy351
Good idea -- we should've posted that link here a long time ago...
Old Sep 11, 2009 | 08:06 PM
  #44
nissandoc's Avatar
nissandoc
Joe, I cant get that video to play. any tips on getting it unzipped. i'm computer challenged on some things.
jeffreyt
419
Apr 12, 2026 05:56 PM
ExPACamper
Jun 3, 2015 04:41 PM
Fishin76
Apr 6, 2015 08:39 AM
Bushwackzach
2004 - 2008 F150
18
Oct 12, 2014 12:34 AM
efair
24
Oct 7, 2014 04:35 PM
