A/C Question
Old Feb 18, 2008 | 06:46 PM
FitchBanjos's Avatar
FitchBanjos
A/C Question
I have a question about the A/C clutch on my 66 F100, 352 engine. Between the a/c clutch and the compressor housing, there is a block where the wiring connects. Mine has a short there and I can push on it with a screwdriver and the compressor will engage. Is that part of the compressor clutch or a seperate piece that I can buy? Is the compressor clutch hard to exchange? Special tools required? Thanks!
Old Feb 20, 2008 | 10:04 AM
66sprintw53's Avatar
66sprintw53
AC clutch
I assume you have the York or Tecumseh compressor. The clutch is composed of 3 seperate parts. The magnetic coil is the piece you are having trouble with. It sounds like you have a broken wire connection rather than a short. I do not know if the coil is available seperately from the complete cluch unit.
It is fairly easy to replace, but you do need a specialized AC tool kit to do so. It may be available for "free rental" from Autozone or other parts stores.
Basically you use a special bolt to remove the hub (outer part) then remove a large snap ring and use a 2 jaw puller to remove the pressed on pulley, then remove the four bolts holding the coil to the front of the compressor. Keep in mind that this is from my rusty memory so don't take it as exact. Best of luck.
Chris
Old Feb 20, 2008 | 10:05 AM
66sprintw53
By the way, where in Texas are you located? I am in Arlington and would be glad to help out.
Chris
Old Feb 26, 2008 | 10:29 AM
66sprintw53
Mr. Fitch
I looked at your banjo site and was very impressed, you do beautiful work!
I also see you are in the DFW area, so the offer stands if you need some help on the AC (especially when it begins to get a little warmer outside).
Chris
Old Feb 26, 2008 | 10:56 AM
FitchBanjos
Thanks Chris ! I will take you up on that ; )
tcjhkbjt
Sep 20, 2016 06:33 PM
DaveTV
Escape & Escape Hybrid
18
Jul 10, 2014 11:23 AM
MagKarl
Sep 11, 2012 07:28 AM
etucker
Aug 30, 2007 12:18 PM
IronMiner
1997 - 2003 F150
Feb 18, 2007 12:54 PM
