Help
Old Feb 17, 2008 | 05:53 PM
Steel357's Avatar
Steel357
Help
I have a 1960 F350 with a 223 and I'm working on getting it started. So I need help on identifying this little nipple that is right below the carb. I can get a vacuum reading from it when I crank the engine. But what's it to? My shop manual doesnt say anything about it.
Here is a picture of it:
Old Feb 17, 2008 | 05:56 PM
bobj49f2's Avatar
bobj49f2
Does your truck have, or did it every have, vacuum wipers? It looks like a vacuum port for the wipers.
Old Feb 17, 2008 | 05:58 PM
Steel357's Avatar
Steel357
yeah it has vaccum wipers, where would the port lead to? Would leaving a hose off that port cause any problems trying to start the engine?
Old Feb 17, 2008 | 06:03 PM
Steel357's Avatar
Steel357
I already have a line that goes from my fuel pump to the wipers though so I'm not sure what this port would be for.
Old Feb 17, 2008 | 06:19 PM
cberry's Avatar
cberry
It attaches to one side of the fuel pump at the top. The other side goes to the wipers. At least that's how mine was set up. I am switching to 12v wipers and capped it off.
Old Feb 17, 2008 | 06:45 PM
cmoritz's Avatar
cmoritz
That looks like direct manifold vacume,it's below the throttle plate.if your not using it for anything, by all means..cap it off. It would be a major vucume leak otherwise and make your engine run ,leaner, because it's sucking air. You need a richer mixture when cold, this open line will not help..I hope that helps.
Old Feb 17, 2008 | 08:04 PM
Steel357's Avatar
Steel357
thanks guys, yeah it seems to work better now that I've capped it.
Old Feb 17, 2008 | 08:20 PM
sandhillmike's Avatar
sandhillmike
My wipers run off that port, but my truck was converted to electic fuel pump by the po
Old Feb 17, 2008 | 08:45 PM
Col Flashman's Avatar
Col Flashman
Do you have a Vaccume Gauge in the Dash Panel?
If so, that what's supposed to be hooked up to it, as far as my book states.
Old Feb 17, 2008 | 09:21 PM
Steel357's Avatar
Steel357
I think it used to have a vacuum gauge, that would make sense i think. There is a random hose that leads into the cab that could maybe fit on that both.
Old Feb 17, 2008 | 09:27 PM
Col Flashman
That'll be it then.
Well it seems you live extremely close to me, as my home is just above Pomona Valley Hospital & we're able to hear the Drags @ Fair Grounds.
Old Feb 17, 2008 | 11:53 PM
Steel357's Avatar
Steel357
yeah I actually used to live in La Verne a few blocks away from the fair grounds. That's cool! It's a bummer though since the truck is out in AZ at my grandpa's house. I go out there every other month or so. I'm hoping to get it out here in CA soon.
