Altenator instalation
Old Feb 16, 2008 | 06:47 PM
AngeliasDad's Avatar
AngeliasDad
Is there a thread for an Altenator Instalation on a 7.3 ltr diesel . I've looked but can't find anything ..... it does'nt look like a tuff instal but any suggestions would be great ....
Old Feb 16, 2008 | 07:03 PM
maevans's Avatar
maevans
Very easy,
Remove the serpentine belt,
two bolts on top of the alternator
and a plug in electrical connection.
15 minute job.
Old Feb 16, 2008 | 07:05 PM
F350-6's Avatar
F350-6
Have you ever removed a serpentine belt? If not you need to locate the tensioner pulley and rotate it with a breaker bar or socket wrench to remove the belt. Then it's just unbolt / bolt as described above.
Old Feb 16, 2008 | 08:14 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Probably the easiest fix to our trucks there is to do. I've done it twice on the side of the road with very limited tools.
Old Feb 16, 2008 | 08:15 PM
bandlgeorge's Avatar
bandlgeorge
Don"t Forget To Disconnect The Batteries Unless You Want To Get Shocked!!!!!! Or Fry Your New Alternator!!!!!
Old Feb 16, 2008 | 09:22 PM
mudmaker's Avatar
mudmaker
I just had to put one on my X in the parking lot at napa this afternoon. On our way to Billings (50 miles) about 1/2 way and the radio quit, about 10 miles further all the gauges quit. I knew what the problem was then. Had it happen 2 times with my pickup except it was night and my lights were dim so I knew I had an issue prior to the dash dying. Anyway, got to town and the climate control quit as I was pulling into napa. 30 minutes later I was on my way. The guys a napa were awesome, loaned me a few wrenches and let me use a booster box.
I've gotta find a nice amp gauge and figure out a nice place to install it!!!
Old Feb 16, 2008 | 10:27 PM
Izzy351's Avatar
Izzy351
I'm putting a Voltage gauge in mine. I'm getting intermittant battery light now, so I need to watch it. This is after a brand new (not rebuilt) AutoZoo DuraLast Gold alternator was put in back in June. The voltage gauge will let you know when the alt is crapping out as you should have about 12.5V-13V with the engine off and around 14ish with it running.
Old Feb 16, 2008 | 10:40 PM
bdrummonds's Avatar
bdrummonds
Joe, I am getting the same issue, ive got a NEW alternator, new battery cables, new batteries, new connector to the alternator, new tensioner, and from time to time I am getting a flashing battery light. The only thing I havent changed (but will soon) is the serp belt, maybe it is slipping. I dont know.
JeffNJF150
22
Jun 11, 2011 07:56 AM
Pete Roberts
Electrical Systems/Wiring
Apr 28, 2011 06:43 PM
49 Ford F-1
Apr 23, 2010 12:13 PM
'88f150w/390bb
Mar 22, 2005 08:08 PM
DGRIMM
1997 - 2003 F150
Mar 19, 2003 11:20 AM
