Altenator Amperage?
Old Apr 17, 2011 | 01:59 PM
Pete Roberts's Avatar
Pete Roberts
Altenator Amperage?
Greetings Everyone...I don't have an ammeter so I am hoping someone knows what the amperage output of a stock altenator for my truck might be. (See my signature below for truck specs).
I am thinking it is 70 amp, but don't know how to tell without an ammeter. Is there a way to tell by just looking at the altenator?
Thanks Guys/Gals,
Pete
Old Apr 17, 2011 | 02:11 PM
HomerWinzlow's Avatar
HomerWinzlow
Some of the older alternators have it stamped into the frame. You might have to remove it to find it.
Old Apr 28, 2011 | 06:43 PM
fmc400's Avatar
fmc400
MSEE
The alternator amperage is a measure of how much current it's rated to produce - not how much it's actually producing at any given time. The alternator only produces the amount of current as instructed by the voltage regulator (internal or external depending on the year). As such, you wouldn't be able to determine its rating by measuring the output current.
Note, however, that you would not want to put your handheld multimeter in series with the alternator output anyways. Many are rated for 10 amps or less, and not all are fused. Not to mention, performing this kind of test around all that grounded metal is a recipe for disaster.
Your best bet would be to try and find it stamped on the alternator housing, as suggested above.
Firefighter 1406
Mar 13, 2015 12:52 PM
zx250
41
Jul 25, 2008 01:25 PM
60RatRod
Electrical Systems/Wiring
May 9, 2008 07:18 PM
xuare
Apr 26, 2003 10:37 PM
