203 stat in
Old Feb 16, 2008 | 05:35 PM
F0rdF0rever's Avatar
F0rdF0rever
203 stat in
I got my dieselsit 203 stat in today. I also replaced the housing while I was at it. While I had some room to work down there I finally was able to pull the sender plug for my water temp gauge. I ended up using the square end of a tap bit to pull it out.
The heat is intense now, I like it. The cab gets warm much quicker now. Heres a pic:
Old Feb 16, 2008 | 10:37 PM
MTNWOODY's Avatar
MTNWOODY
I have my new stat and housing from Deiselsite sitting in boxes in my gargage...
I hope to see the same gauge results tommorrow. Notice anything performance wise?
Old Feb 17, 2008 | 07:07 AM
MADVAN's Avatar
MADVAN
Excellent!!!
Just remember come spring you might want to remove the trans fluid from the rad.
Bill
Old Feb 17, 2008 | 08:19 AM
Cuda_jim's Avatar
Cuda_jim
Originally Posted by MADVAN
Excellent!!!
Bill
Bill, ?? Can you elaborate? I am about to make the switch over to a 203 stat, I don't want to miss something.
Old Feb 17, 2008 | 01:01 PM
IceboxFX's Avatar
IceboxFX
i think he means bypass the radiator so the trans fluid does not go in there since its gonna be hotter now, but i could be wrong.
Old Feb 17, 2008 | 03:11 PM
tjbeggs's Avatar
tjbeggs
yeah thats what he is talking about. Hotter coolant hotter trans fluid.
Old Feb 17, 2008 | 03:26 PM
F0rdF0rever
I did think about that when I was installing the stat. My trans already runs hot in the summer months. I need a bigger cooler on it badly. Thats my next mod on the list.
Steve
Old Feb 17, 2008 | 04:50 PM
bkcowboss's Avatar
bkcowboss
all right, now my curiosity is peaked, our trans fluid runs in the radiator and then through the trans cooler? and how do we bypass it? does that apply to the 03 bill ?
Old Feb 17, 2008 | 04:53 PM
tjbeggs's Avatar
tjbeggs
yes our trans coolers go thru the in rad cooler than to the air to oil then back to the trans. The 03 I am not sure. at some point they quit the in rad coolers. to bypass the in rad cooler just take out the lines and cap the holes. Run whatever hose is needed to couple the lines back together.
Old Feb 17, 2008 | 05:03 PM
bkcowboss's Avatar
bkcowboss
Well I am going to have to take a look at that, so I can assume that if I see the lines enter and exit the base of the radiator that it has a fluid to fluid cooling ?
Old Feb 17, 2008 | 05:08 PM
tjbeggs's Avatar
tjbeggs
yep cooler lines in the bottom of rad you have fluid to fluid cooler.
Old Feb 17, 2008 | 07:38 PM
MADVAN's Avatar
MADVAN
Yup!
You guy's are correct. Thing is no 2 trucks are used the same.
Along with the trans. Its just something to watch for come spring time.
I remove in summer (aver 20* cooler). Reinstall for winter. I have transfer
shutoff valves.
Bill
Old Feb 17, 2008 | 09:41 PM
MTNWOODY's Avatar
MTNWOODY
I did not see any change in my tranny temp today after installing the 203* t-stat. I will have to look at the configuration tommorow. I did notice a nice increase in water/coolant temp.. TRG...203* added to sig.
Old Feb 18, 2008 | 07:12 AM
Knotwild's Avatar
Knotwild
I think the real boost with the 203 comes when the old thermostat is so worn out that it isn't working properly. Mine was so shot that the EOT never got past 155-160, so the PCM wasn't sending the right tuning info to the engine and it was running crappy from 1000 to 2000 rpms. When I put the 203 in, it was like buying a new truck. It accelerates smoothly and with power through those ranges now, even without downshifting.
Old Feb 18, 2008 | 07:36 AM
F0rdF0rever
Same thing with mine. The old one was dead. My gauge wouldnt even reach the N in normal. Now with the new one it runs much better.
